PETSc convergence criteria
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 27 13:51:49 CDT 2008
Also run with -ksp_converged_reason to see why the KSP solver is
stopping.
You can also run with -ksp_monitor_true_residual to see what is
happening to
the preconditioned residual norm and nonpreconditioned residual norm
during the
computation.
Barry
On Aug 27, 2008, at 1:39 PM, Matthew Knepley wrote:
> You are using the preconditioned norm for the convergence test. You
> can use
> KSPSetNormType(ksp, KSP_NORM_UNPRECONDITIONED)
> However, this will not work for all KSP types.
> Matt
> On Wed, Aug 27, 2008 at 1:23 PM, Nguyen, Hung V ERDC-ITL-MS
> <Hung.V.Nguyen at usace.army.mil> wrote:
>> All,
>> We run a test case with -ksp_rtol 1.0e-15 and -ksp_max_it 50000.
>> Then we
>> compute the infinity and 2 norms of |a * xsolution -b| and the
>> results are
>> below. Why are these values of norms in a range 10e-8 to 10e-10 while
>> -ksp_rtol is set 1.0e-15? What is the PETSc convergence criteria
>> for the
>> matrix solver?
>> Thank you in advance,
>> -Hung
>>> hvnguyen:jade20% aprun -n 16 ./fw -ksp_type cg -pc_type bjacobi
>>> -ksp_rtol 1.0e-15 -ksp_max_it 50000
>>> Time in PETSc solver = 0.7661848068237305 sec
>>> Computed solution - 2 norm of the residual error =
>>> 1.0662412498046400E-008
>>> Computed solution - maximum residual error (infinity norm) =
>>> 5.2750692702829838E-010
>>> Number of Krylov iterations = 257
>>> Application 281373 resources: utime 0, stime 0
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
