PETSc convergence criteria
Nguyen, Hung V ERDC-ITL-MS
Hung.V.Nguyen at usace.army.mil
Wed Aug 27 13:23:52 CDT 2008
All,
We run a test case with -ksp_rtol 1.0e-15 and -ksp_max_it 50000. Then we
compute the infinity and 2 norms of |a * xsolution -b| and the results are
below. Why are these values of norms in a range 10e-8 to 10e-10 while
-ksp_rtol is set 1.0e-15? What is the PETSc convergence criteria for the
matrix solver?
Thank you in advance,
-Hung
> hvnguyen:jade20% aprun -n 16 ./fw -ksp_type cg -pc_type bjacobi
> -ksp_rtol 1.0e-15 -ksp_max_it 50000
> Time in PETSc solver = 0.7661848068237305 sec
> Computed solution - 2 norm of the residual error =
> 1.0662412498046400E-008
> Computed solution - maximum residual error (infinity norm) =
> 5.2750692702829838E-010
> Number of Krylov iterations = 257
> Application 281373 resources: utime 0, stime 0
