MatGetVecs and MATMFFD
Boyce Griffith griffith at courant.nyu.edu
Thu Aug 21 12:29:46 CDT 2008
On Thu, 21 Aug 2008, Matthew Knepley wrote:
> On Thu, Aug 21, 2008 at 11:58 AM, Boyce Griffith
> <griffith at courant.nyu.edu> wrote:
>> On Thu, 21 Aug 2008, Lisandro Dalcin wrote:
>>> On Thu, Aug 21, 2008 at 1:23 PM, Boyce Griffith
>>>> Is there any way to associate a context with a MFFD matrix?  It seems
>>>> like
>>>> the Otherwise, it seems like the implementation of MatGetVecs would need
>>>> to
>>>> use global variables in order to create the appropriate vectors.
>>> You can use a PetscContainer (see PetscContainerCreate() and friends)
>>> to save your user data and then you can set put that container in any
>>> PETSc object with PetscObjectCompose(), and next retrieve the
>>> container with PetscObjectQuery(), and finally recover your user data
>>> with PetscContainerGetPointer().
>> Sounds like that should do the trick.
>>>> Or is it possible to get access to the solution and right-hand-side
>>>> vectors
>>>> used by an associated SNES and use VecDuplicate on them?
>>> You can use SNESGetRhs() and SNESGetSolution(). At least in petsc-dev
>>> (not so sure in last public release, I do not remember), you will get
>>> back a reference to the 'b' and 'x' Vec's you passed to
>>> 'SNESSolve(snes, b, x)'. You can even SNESGetSolutionUpdate() for
>>> getting the Vec where the solution update for the Newton step is
>>> formed.
>> Right, but if all I have is the Mat, is there a userland function which will
>> return the corresponding SNES?
> There is no SNES that corresponds to a Mat, rather the SNES holds a Mat,
> which is oblivious. The MatGetVecs() routine is there to provide vectors
> which have a layout that matches the Mat. This is done by using the same
> PetscMap as the matrix rows.
Presumably it isn't *totally* oblivious, otherwise MatCreateMFFD wouldn't
take a SNES as an argument?
-- Boyce
>   Matt
>> Thanks,
>> -- Boyce
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
