strange convergency behavior with petsc (intialy produces good result, suddenly diverges)
Barry Smith
bsmith at mcs.anl.gov
Sun Aug 17 09:32:40 CDT 2008
Try using -pc_type sor -pc_sor_local_symmetric -ksp_type cg
Also try running the original icc one with the additional option -
ksp_monitor_true_residual, see if funky stuff starts to happen.
You could also try adding -pc_factor_levels 1 to try ICC(1)
instead of ICC(0).
Your code looks fine, I don't see a problem there,
Barry
Here is my guess, as the simulation proceeds the variable
coefficient problem changes enough so that the ICC produces
a badly scaled preconditioner that messes up the iterative method. I
see this on occasion and don't have a good fix, the shift
positive definite helps sometimes but not always.
On Aug 17, 2008, at 3:36 AM, Shengyong wrote:
> Hi,
> I am still struggling to use petsc to solve variable coefficient
> poisson problems (which orinates from a multi-phase(liquid-gas two
> phase flow with sharp interface method, the density ratio is 1000,
> and with surface tension) flow problem) successively.
> Initially petsc produces good results with icc pc_type , cg
> iterative method and with _pc_factor_shift_positive_define flag. I
> follow petsc's null space method to constrain the singular property
> of coefficient matrix. However, after several time steps good
> results of simulation, the KSP Residual Norm suddenly reaches to a
> number greater than 1000. I guess that petsc diverges. I have also
> tried to swith to other types of methods, e.g. to gmeres, it just
> behaves similar to cg method. However, when I use my previous self-
> coded SOR iterative solver, it produces nice results. And I have
> tested the same petsc solver class for a single phase driven cavity
> flow problem, it also produces nice results.
> It seems that I have missed something important setup procedure in
> my solver class. could anyone to point me the problem ? I have
> attached large part of the code below:
> //in Header
> class CPETScPoissonSolver
> typedef struct {
> Vec x,b; //x, b
> Mat A; //A
> KSP ksp; //Krylov subspace preconditioner
> PC pc;
> MatNullSpace nullspace;
> PetscInt l, m, n;//L, M, N
> } UserContext;
> public:
> CPETScPoissonSolver(int argc, char** argv);
> ~CPETScPoissonSolver(void);
> private:
> //Yale Sparse Matrix format matrix
> PetscScalar* A;
> PetscInt * I;
> PetscInt * J;
> // Number of Nonzero Element
> PetscInt nnz;
> //grid step
> PetscInt L, M, N;
> UserContext userctx;
> private:
> bool FirstTime;
> //in cpp
> static char helpPetscPoisson[] = "PETSc class Solves a variable
> Poisson problem with Null Space Method.\n\n";
> CPETScPoissonSolver::CPETScPoissonSolver(int argc, char** argv)
> PetscInitialize(&argc, &argv, (char*)0, helpPetscPoisson);
> FirstTime=true;
> CPETScPoissonSolver::~CPETScPoissonSolver(void)
> PetscFinalize();
> void CPETScPoissonSolver::SetAIJ(PetscScalar *a, PetscInt *i,
> PetscInt *j, PetscInt Nnz)
> A= a; I=i; J=j; nnz = Nnz;
> PetscErrorCode CPETScPoissonSolver::UserInitializeLinearSolver()
> PetscErrorCode ierr = 0;
> PetscInt Num = L*M*N;
> //Since we use successive solvers, so in the second time step we
> must deallocate the original matrix then setup a new one
> if(FirstTime==true)
> ierr = MatCreateSeqAIJWithArrays(PETSC_COMM_SELF, Num,
> Num, I, J, A, &userctx.A); CHKERRQ(ierr);
> else
> FirstTime = false;
> ierr = MatDestroy(userctx.A);CHKERRQ(ierr);
> if(FirstTime==true)
> ierr =
> VecCreateSeqWithArray
> (PETSC_COMM_SELF,Num,PETSC_NULL,&userctx.b);CHKERRQ(ierr);
> ierr = VecDuplicate(userctx.b,&userctx.x);CHKERRQ(ierr);
> ierr = MatNullSpaceCreate(PETSC_COMM_SELF, PETSC_TRUE, 0,
> PETSC_NULL, &userctx.nullspace); CHKERRQ(ierr);
> ierr = KSPCreate(PETSC_COMM_SELF,&userctx.ksp);CHKERRQ(ierr);
> /*Set Null Space for KSP*/
> ierr = KSPSetNullSpace(userctx.ksp,
> userctx.nullspace);CHKERRQ(ierr);
> return 0;
> PetscErrorCode CPETScPoissonSolver::UserSetBX(PetscScalar *x,
> PetscScalar *b)
> PetscErrorCode ierr ;
> //below code we must set it every time step
> ierr = VecPlaceArray(userctx.x,x);CHKERRQ(ierr);
> ierr = VecPlaceArray(userctx.b,b);CHKERRQ(ierr);
> ierr = MatNullSpaceRemove(userctx.nullspace,userctx.b,
> PETSC_NULL);CHKERRQ(ierr);
> return 0;
> PetscInt CPETScPoissonSolver::UserSolve()
> PetscErrorCode ierr;
> ierr =
> KSPSetOperators
> (userctx.ksp,userctx.A,userctx.A,SAME_NONZERO_PATTERN);CHKERRQ(ierr);
> ierr = KSPSetType(userctx.ksp, KSPCG);
> ierr = KSPSetInitialGuessNonzero(userctx.ksp, PETSC_TRUE);
> ierr = KSPGetPC(userctx.ksp,&userctx.pc);CHKERRQ(ierr);
> ierr = PCSetType(userctx.pc,PCICC);CHKERRQ(ierr);
> ierr = PCFactorSetShiftPd(userctx.pc, PETSC_TRUE);
> ierr = KSPSetTolerances(userctx.ksp,
> 1.e-4,PETSC_DEFAULT,PETSC_DEFAULT,2000);
> ierr = KSPSetFromOptions(userctx.ksp);CHKERRQ(ierr);
> Solve the linear system
> ierr = KSPSolve(userctx.ksp,userctx.b,userctx.x);CHKERRQ(ierr);
> ierr = VecResetArray(userctx.x);CHKERRQ(ierr);
> ierr = VecResetArray(userctx.b);CHKERRQ(ierr);
> return 0;
> PetscErrorCode CPETScPoissonSolver::ReleaseMem()
> ierr = KSPDestroy(userctx.ksp);CHKERRQ(ierr);
> ierr = VecDestroy(userctx.x); CHKERRQ(ierr);
> ierr = VecDestroy(userctx.b); CHKERRQ(ierr);
> ierr = MatDestroy(userctx.A); CHKERRQ(ierr);
> ierr = MatNullSpaceDestroy(userctx.nullspace); CHKERRQ(ierr);
> return 0;
> Thanks very much!
> Pang Shengyong
> Solidification Simulation Lab,
> State Key Lab of Mould & Die Technology,
> Huazhong Univ. of Sci. & Tech. China
