compiling PETSc with Intel MKL 10.0.1.14
Paul T. Bauman
pbauman at ices.utexas.edu
Fri Aug 15 13:39:52 CDT 2008
Was there ever a fix/workaround introduced for this? I'm using 2.3.3p13
and I'm having trouble getting the config to recognize mkl 10.0.3.020.
Paul
Barry Smith wrote:
> Could you email to petsc-maint at mcs.anl.gov ALL the messages as to
> what goes wrong with
> our current linking so we can fix it?
> Thanks
> Barry
> On Jun 18, 2008, at 3:32 PM, Randall Mackie wrote:
>> We've upgraded Intel MKL to version 10.0, but in this version, Intel has
>> changed how libraries are suppose to be linked. For example, the
>> libmkl_lapack.a
>> is a dummy library, but that's what the PETSc configure script looks
>> for.
>> The documentation says, for example, to compile LAPACK in the static
>> case,
>> use libmkl_lapack.a libmkl_em64t.a
>> and in the layered pure case to use
>> libmkl_intel_lp64.a libmkl_intel_thread.a libmkl_core.a
>> However, the PETSC configuration wants -lmkl_lapack -lmkl -lguide
>> -lpthread
>> Any suggestions are appreciated.
>> Randy
