problem in compiling petsc for visual c++ 2005
berry lua.byhh at gmail.com
Tue Aug 12 09:26:23 CDT 2008
Thanks,  I have already logged into the cygwin from VC command prompt.
On Tue, Aug 12, 2008 at 10:21 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 12 Aug 2008, berry wrote:
> > Hi, Matt
> > Previously I installed petsc on cygwin following the official guide from
> > petsc website. Because I started from cygwin shell, so both' mkdir 'and
> > 'sed' command are transparent for petsc configure script.
> > But for VC 2005 version, I start from VC 2005 command line prompt, and
> type:
> > c:\cygwin\bin\bash , then going to the bash shell. I am not sure why in
> this
> > way the installation script can not see the 'sed' and 'mkdir'. By the
> way,
> > it also miss python. So I give an absolute path for executing
> configure.py.
> > Although it starts to run the configure.py script, it misses some command
> > line utilities in sub installation script.
> try
> c:\cygwin\bin\bash --login
> and then verify if 'mkdir', 'sed' etc are in your PATH
> which sed
> which mkdir
> Satish
Pang Shengyong
Solidification Simulation Lab,
State Key Lab of Mould & Die Technology,
Huazhong Univ. of Sci. & Tech. China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080812/d7e1d12d/attachment.htm>
