problem in compiling petsc for visual c++ 2005
Matthew Knepley
knepley at gmail.com
Tue Aug 12 06:34:52 CDT 2008
On Tue, Aug 12, 2008 at 5:18 AM, berry <lua.byhh at gmail.com> wrote:
> Hi,
> I am trying to compile PETSC in cygwin for Visual c++ 2005. I follow the
> guide exactly from here:
> http://www-unix.mcs.anl.gov/petsc/petsc-2/documentation/installation.html.
> and use below command:
> /usr/bin/python ./config/configure.py --with-cc='win32fe cl --nodetect'
> --with-fc='win32fe ifort --nodetect' --with-mpi=1 --with-f-blas-lapack=1
> --with-hypre=1
> PETSC installation script really starts to run. However, it fails with
> below errors:
> Configuring PETSc to compile on your system
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> detail
> s):
> Unable to determine host type using
> /cygdrive/c/cygwin/home/pangshengyong/soft/p
> etsc-2.3.3-p13/python/BuildSystem/config/packages/config.sub: Could not
> execute
> '/bin/sh
> /cygdrive/c/cygwin/home/pangshengyong/soft/petsc-2.3.3-p13/python/Build
> System/config/packages/config.guess':
> /cygdrive/c/cygwin/home/pangshengyong/soft/petsc-2.3.3-p13/python/BuildSystem/co
> nfig/packages/config.guess: line 38: sed: command not found
> nfig/packages/config.guess: line 1272: mkdir: command not found
> : cannot create a temporary directory in /tmp
> It seems that the configure script miss to find the correct path. Does
> anyone could point me out how to set the correct path for configure script
> please?
> Btw: I have successfully compiled petsc library on cygwin for gcc.
I am not sure how you built PETSc on cygwin before. Perhaps a different
copy? This
error seems to occur because you cygwin is missing the command line
utilities
'sed' and 'mkdir'.
Matt
> Thanks.
> Pang Shengyong
> Solidification Simulation Lab,
> State Key Lab of Mould & Die Technology,
> Huazhong Univ. of Sci. & Tech. China
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080812/2c4e11ab/attachment.htm>
