KSPSetNullSpace and CG for singular systems
Stephan Kramer stephan.kramer at imperial.ac.uk
Sat Aug 2 05:04:06 CDT 2008
Shao-Ching Huang wrote:
> Hi,
> I am trying to use CG to solve a singular systems (i.e. Poisson
> equation with periodic conditions on all boundaries).
> The code works when I use GMRES, but it diverges when I switch CG.
> Since the null space is a constant vector, in the code I have:
I might be missing something here, but aren't linearly varying vectors
in your null space as well?
Cheers
Stephan
>    KSP ksp;
>    MatNullSpace nullspace;
>    MatNullSpaceCreate(MPI_COMM_WORLD, PETSC_TRUE, 0, PETSC_NULL, &nullspace);
>    KSPSetNullSpace(ksp, nullspace);
>    MatNullSpaceRemove(nullspace, f->p_rhs, PETSC_NULL);
>    KSPSetFromOptions(ksp);
>    KSPSetUp(ksp);
>    KSPSolve(ksp, f->p_rhs, f->phi);
> [f->p_rhs is the RHS vector. f->phi is the solution vector.]
> When I use "-ksp_type gmres", it converges (shown by -ksp_monitor).
> However, when I switch to "-ksp_type cg", it diverges.
> In this case (cg), "-ksp_converged_reason" says:
>   Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 1
> I also try adding "-sub_pc_factor_shift_nonzero 0.0000000001" but the
> CG case still fails.
> Am I missing some step in handling the null space when using CG?
> Thanks,
> Shao-Ching Huang
