[mumps-dev] Re: Question on using MUMPS in PETSC
    Randall Mackie
    rlmackie862 at gmail.com
    Fri Aug  1 19:49:37 CDT 2008
Barry,
No, this is the same program I've used quite successfully using iterative
methods within PETSc for years. Each processors portion of the matrix
is constructed on the individual processors.
In fact, I downloaded and recompiled PETSc to use SUPERLU, and using the exact
same program, but changing the matrix type from aijmumps to superlu_dist,
and it worked just fine.
So, I'm not sure why MUMPS is not working.
Randy
Barry Smith wrote:
>   Are you sure you are not constructing the original matrix with all its
> rows and columns
> on the first process?
>   Barry
> On Aug 1, 2008, at 5:49 PM, Randall Mackie wrote:
>> In fact, during the Analysis step, the max amount of memory 300 Mbytes is
>> used by one process. However, during the Factorization stage, that
>> same process
>> then starts to increase in memory, with all the other processes
>> staying the same.
>> I've re-run this several times using different numbers of processors,
>> and I
>> keep getting the same behavior.
>> Randy
>> Jean-Yves L Excellent wrote:
>>> Hi,
>>> Clearly in MUMPS processor 0 uses more memory during
>>> the analysis step because the analysis is sequential.
>>> So until we provide a parallel analysis, processor 0
>>> is gathering the graph of the matrix from all other
>>> processors to perform the analysis. But that memory
>>> is freed at the end of the analysis so it should
>>> not affect the factorization.
>>> Thanks for letting us know if you have more information.
>>> Regards,
>>> Jean-Yves
>>> Hong Zhang wrote:
>>>> Randy,
>>>> The petsc interface does not create much of extra
>>>> memories.
>>>> The analysis phase of MUMPS solver is sequential - which might
>>>> causes one process blow up with memory.
>>>> I'm forwarding this email to the mumps developer
>>>> for their input.
>>>> Jean-Yves,
>>>> What do you think about the reported problem
>>>> (see attached below)?
>>>> Thanks,
>>>> Hong
>>>> On Thu, 31 Jul 2008, Randall Mackie wrote:
>>>>> Barry,
>>>>> I don't think it's the matrix - I saw the same behavior when I ran
>>>>> your
>>>>> ex2.c program and set m=n=5000.
>>>>> Randy
>>>>> Barry Smith wrote:
>>>>>>   If m and n are the number of rows and columns of the sparse
>>>>>> matrix (i.e. it is
>>>>>> tiny problem) then please
>>>>>> send us matrix so we can experiment with it to
>>>>>> petsc-maint at mcs.anl.log
>>>>>>  You can send us the matrix by simply running with
>>>>>> -ksp_view_binary and
>>>>>> sending us the file binaryoutput.
>>>>>>   Barry
>>>>>> On Jul 31, 2008, at 5:56 PM, Randall Mackie wrote:
>>>>>>> When m = n = small (like 50), it works fine. When I set m=n=5000,
>>>>>>> I see
>>>>>>> the same thing, where one process on the localhost is taking >4 G
>>>>>>> of RAM,
>>>>>>> while all other processes are taking 137 M.
>>>>>>> Is this the standard behavior for MUMPS? It seems strange to me.
>>>>>>> Randy
>>>>>>> Matthew Knepley wrote:
>>>>>>>> Does it work on KSP ex2?
>>>>>>>> Matt
>>>>>>>> On Thu, Jul 31, 2008 at 4:35 PM, Randall Mackie
>>>>>>>> <rlmackie862 at gmail.com> wrote:
>>>>>>>>> I've compiled PETSc with MUMPS support, and I'm trying to run a
>>>>>>>>> small test
>>>>>>>>> problem, but I'm having some problems. It seems to begin just
>>>>>>>>> fine, but
>>>>>>>>> what I notice is that on one process (out of 64), the memory
>>>>>>>>> just keeps
>>>>>>>>> going up and up and up until it crashes, while on the other
>>>>>>>>> processes,
>>>>>>>>> the memory usage is reasonable. I'm wondering if anyone might
>>>>>>>>> have any idea
>>>>>>>>> why? By the way, my command file is like this:
>>>>>>>>> -ksp_type preonly
>>>>>>>>> -pc_type lu
>>>>>>>>> -mat_type aijmumps
>>>>>>>>> -mat_mumps_cntl_4 3
>>>>>>>>> -mat_mumps_cntl_9 1
>>>>>>>>> Randy
>>>>>>>>> ps. This happens after the analysis stage and in the
>>>>>>>>> factorization stage.
