Petsc with hypre
Adrian Tate adrian at cray.com
Fri Aug 1 13:29:02 CDT 2008
Dear Hung
We have asked your site staff to install the Cray Petsc package on sapphire, so you also now have the option of using that. If you have problems using that package please email Keita Teranishi and myself.
Adrian Tate
Math SW Group Lead
Cray Inc.
(206) 349 5868
----- Original Message -----
From: owner-petsc-users at mcs.anl.gov <owner-petsc-users at mcs.anl.gov>
To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Cc: Keita Teranishi
Sent: Fri Aug 01 11:18:31 2008
Subject: RE: Petsc with hypre
I am able to install hypre, but fail to install petsc with including hypre.
1. I have been trying to get PETSc to download and install its own version of
HYPRE -- and failed with the error
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Error running configure on HYPRE: Could not execute 'cd
/work/hvnguyen/work_project/petsc-2.3.3-p3/externalpackages/hypre-2.0.0/src;m
ake distclean;./configure
--prefix=/work/hvnguyen/work_project/petsc-2.3.3-p3/externalpackages/hypre-2.
0.0/CrayXT3-O CC="cc  -fPIC -fastsse -O3 -Munroll=c:4 -tp k8-64 " CXX="CC  -O
-fPIC " F77="ftn  -fPIC -fastsse -O3 -Munroll=c:4 -tp k8-64  "
--with-MPI-include="/opt/xt-mpt/default/mpich2-64/P2/include"
--with-MPI-lib-dirs="" --with-MPI-libs="" --with-blas-libs=
--with-blas-lib-dir= --with-lapack-libs= --with-lapack-lib-dir=
--with-blas=yes --with-lapack=yes --without-babel --without-mli --without-fei
--without-superlu':
Dist-cleaning utilities ...
make[1]: Entering directory
`/work/hvnguyen/work_project/petsc-2.3.3-p3/externalpackages/hypre-2.0.0/src/
utilities'
rm -f *.o libHYPRE* f2c.h *blas.h *lapack.h
2. I tried to install hypre and it works (I tested their example codes). The,
I try to install petsc with config option below, but -no success, see error
 hvnguyen:sapphire01% config/configure.py --with-batch=1 --with-mpi-shared=0
--with-memcmp-ok --sizeof_char=1 --sizeof_void_p=8 --sizeof_short=2
--sizeof_int=4 --sizeof_long=8 --sizeof_long_long=8 --sizeof_float=4
--sizeof_double=8 --bits_per_byte=8 --sizeof_MPI_Comm=4 --sizeof_MPI_Fint=4
--with-fc=ftn --with-cc=cc --with-cxx=CC -PETSC_ARCH=CrayXT3-O
--with-debugging=0 --with-error-checking=0 COPTFLAGS="-fastsse -O3
-Munroll=c:4 -tp k8-64" FOPTFLAGS="-fastsse -O3 -Munroll=c:4 -tp k8-64"
--with-x=0 --with-mpi-dir=/opt/xt-mpt/default/mpich2-64/P2 --with-shared=0
--with-hypre-include=/work/hvnguyen/work_project/hypre-2.0.0/small/fastsse/in
clude
--with-hypre-lib=[/work/hvnguyen/work_project/hypre-2.0.0/small/fastsse/lib/l
ibHYPRE.a,-lHYPRE_DistributedMatrix,-lHYPRE_DistributedMatrixPilutSolver,-lHY
PRE_Euclid,-lHYPRE_FEI,-lHYPRE_IJ_mv,-lHYPRE_LSI,-lHYPRE_MatrixMatrix,-lHYPRE
_ParaSails,-lHYPRE_ParaSails,-lHYPRE_mli,-lHYPRE_multivector,-lHYPRE_parcsr_b
lock_mv,-lHYPRE_parcsr_ls,-lHYPRE_parcsr_mv,-lHYPRE_seq_mv,-lHYPRE_sstruct_ls
,-lHYPRE_sstruct_mv,-lHYPRE_sstruct_mv,-lHYPRE_utilities
-- error:
TESTING: check from
config.libraries(/work/hvnguyen/work_project/petsc-2.3.3-p3/python/BuildSyste
m/config/libraries.py:108)
details):
--with-hypre-lib=['[/work/hvnguyen/work_project/hypre-2.0.0/small/fastsse/lib
/libHYPRE.a,-lHYPRE_DistributedMatrix,-lHYPRE_DistributedMatrixPilutSolver,-l
HYPRE_Euclid,-lHYPRE_FEI,-lHYPRE_IJ_mv,-lHYPRE_LSI,-lHYPRE_MatrixMatrix,-lHYP
RE_ParaSails,-lHYPRE_ParaSails,-lHYPRE_mli,-lHYPRE_multivector,-lHYPRE_parcsr
_block_mv,-lHYPRE_parcsr_ls,-lHYPRE_parcsr_mv,-lHYPRE_seq_mv,-lHYPRE_sstruct_
ls,-lHYPRE_sstruct_mv,-lHYPRE_sstruct_mv,-lHYPRE_utilities'] and
clude did not work
Thanks for your help.
-Hung
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On
Behalf Of Barry Smith
Sent: Wednesday, July 30, 2008 10:28 AM
Cc: Keita Teranishi
Subject: Re: Petsc with hypre
    If PETSc is built from source then it, by default, does not include hypre
and other external packages. You should install PETSc yourself and include
the additional config/configure.py option --download-hypre
    Barry
On Jul 30, 2008, at 9:18 AM, Nguyen, Hung V ERDC-ITL-MS wrote:
> Hello Keita,
>> Did this error happen with Cray's PETSc?
> I am running my code in Cray XT3 (at ERDC). Please find the current
> and available modules in the system below.
> I think I amn't using Cray's PETSC since I am using the one from the
> location /usr/local/usp/PETtools/CE/MATH/petsc-2.3.3-p3.
> How do I use Cray's PETSC? Which module I need to load?
> Thanks,
> -Hung
> --- current module:
> hvnguyen:sapphire12% module list
> Currently Loaded Modulefiles:
>  1) modules/3.1.6         5) xt-libsci/1.5.52      9) xt-pbs/5.3.5
> 13) xt-catamount/1.5.52  17) Base-opts/1.5.52
>  2) MySQL/4.0.27          6) xt-mpt/1.5.52        10) xt-service/
> 1.5.52
> 14) xt-boot/1.5.52
>  3) acml/3.6              7) xt-pe/1.5.52         11) xt-libc/1.5.52
> 15) xt-crms/1.5.52
>  4) pgi/7.0.6             8) PrgEnv-pgi/1.5.52    12) xt-os/1.5.52
> 16) xt-lustre-ss/1.5.52
> hvnguyen:sapphire12% module avai
> /opt/modulefiles
> ---------------------------------------------------------------Base-
> opts/1.4.
> 10             craypat/3.2.3                xt-catamount/1.4.43
> xt-mpt/1.4.10
> Base-opts/1.4.38             dwarf/6.10.0                 xt-
> catamount/1.5.16
> xt-mpt/1.4.38
> Base-opts/1.4.43             elf/0.8.6(default)           xt-
> catamount/1.5.27
> xt-mpt/1.4.43
> Base-opts/1.5.16             fftw/2.1.5(default)          xt-
> catamount/1.5.39
> xt-mpt/1.5.16
> Base-opts/1.5.27             fftw/3.1.1
> xt-catamount/1.5.39.nic10    xt-mpt/1.5.27
> Base-opts/1.5.39             gcc/3.2.3                    xt-
> catamount/1.5.52
> xt-mpt/1.5.39
> Base-opts/1.5.52(default)    gcc/4.1.1(default)
> xt-craypat/4.0(default)      xt-mpt/1.5.52
> MySQL/4.0.27                 glib/2.4.2                   xt-crms/
> 1.4.10
> xt-mpt-gnu/1.4.10
> PrgEnv/1.4.10                gmalloc                      xt-crms/
> 1.4.38
> xt-mpt-gnu/1.4.38
> PrgEnv/1.4.38                gnet/2.0.5                   xt-crms/
> 1.4.43
> xt-mpt-gnu/1.4.43
> PrgEnv/1.4.43                iobuf/1.0.2                  xt-crms/
> 1.5.16
> xt-mpt-gnu/1.5.16
> PrgEnv-gnu/1.4.10            iobuf/1.0.5(default)         xt-crms/
> 1.5.27
> xt-mpt-gnu/1.5.27
> PrgEnv-gnu/1.4.38            iobuf/1.0.6                  xt-crms/
> 1.5.39
> xt-mpt-gnu/1.5.39
> PrgEnv-gnu/1.4.43            libscifft-pgi/1.0.0(default) xt-crms/
> 1.5.52
> xt-mpt-gnu/1.5.52
> PrgEnv-gnu/1.5.16            modules/3.1.6                xt-libc/
> 1.4.10
> xt-mpt-pathscale/1.5.39
> PrgEnv-gnu/1.5.27            papi/3.2.1(default)          xt-libc/
> 1.4.38
> xt-mpt-pathscale/1.5.52
> PrgEnv-gnu/1.5.39            papi/3.5.0C.1                xt-libc/
> 1.4.43
> xt-os/1.4.10
> PrgEnv-gnu/1.5.52(default)   pathscale/2.5                xt-libc/
> 1.5.16
> xt-os/1.4.38
> PrgEnv-pathscale/1.5.39      pathscale/3.0(default)       xt-libc/
> 1.5.27
> xt-os/1.4.43
> PrgEnv-pathscale/1.5.52      pgi/6.2.5                    xt-libc/
> 1.5.39
> xt-os/1.5.16
> PrgEnv-pgi/1.4.10            pgi/7.0.2                    xt-libc/
> 1.5.52
> xt-os/1.5.27
> PrgEnv-pgi/1.4.38            pgi/7.0.3                    xt-libsci/
> 1.4.10
> xt-os/1.5.39
> PrgEnv-pgi/1.4.43            pgi/7.0.4                    xt-libsci/
> 1.4.38
> xt-os/1.5.52
> PrgEnv-pgi/1.5.16            pgi/7.0.5                    xt-libsci/
> 1.4.43
> xt-papi/3.5.99a(default)
> PrgEnv-pgi/1.5.27            pgi/7.0.6(default)           xt-libsci/
> 1.5.16
> xt-pbs/5.3.5
> PrgEnv-pgi/1.5.39            pgi/7.0.7                    xt-libsci/
> 1.5.27
> xt-pe/1.4.38
> PrgEnv-pgi/1.5.52(default)   pgi/7.1.2                    xt-libsci/
> 1.5.39
> xt-pe/1.4.43
> acml/3.0                     pgi/7.1.4
> xt-libsci/1.5.52(default)    xt-pe/1.5.16
> acml/3.6(default)            pgi32/6.1.1                  xt-libsci/
> 10.2.0
> xt-pe/1.5.27
> acml/4.0.1a                  pkg-config/0.15.0            xt-lsfhpc/
> 6.1
> xt-pe/1.5.39
> acml-gnu/3.0                 xt-boot/1.4.10               xt-lustre-
> ss/1.4.10
> xt-pe/1.5.52
> acml-large_arrays/3.0        xt-boot/1.4.38               xt-lustre-
> ss/1.4.38
> xt-service/1.4.10
> acml-mp/3.0                  xt-boot/1.4.43               xt-lustre-
> ss/1.4.43
> xt-service/1.4.38
> apprentice2/3.0.1(default)   xt-boot/1.5.16               xt-lustre-
> ss/1.5.16
> xt-service/1.4.43
> apprentice2/3.2.3            xt-boot/1.5.27               xt-lustre-
> ss/1.5.27
> xt-service/1.5.16
> apprentice2/4.0              xt-boot/1.5.39               xt-lustre-
> ss/1.5.39
> xt-service/1.5.27
> craypat/3.0.1                xt-boot/1.5.52
> xt-lustre-ss/1.5.39.bogl1    xt-service/1.5.39
> craypat/3.1.1                xt-catamount/1.4.10
> xt-lustre-ss/1.5.39.nic10    xt-service/1.5.52
> craypat/3.1.2(default)       xt-catamount/1.4.38          xt-lustre-
> ss/1.5.52
> From: Keita Teranishi [mailto:keita at cray.com]
> Sent: Wednesday, July 30, 2008 9:09 AM
> Cc: Nguyen, Hung V ERDC-ITL-MS
> Hi Hung,
> Did this error happen with Cray's PETSc?  Our PETSc supports both
> hypre and ParMetis.
> Please let me know more details with your error (such as module
> environment).
> Thanks,
> Keita Teranishi
> Math Software Group
> Cray, Inc.
> keita at cray.com
> ] On
> Behalf Of Nguyen, Hung V ERDC-ITL-MS
> Sent: Wednesday, July 30, 2008 8:57 AM
> Subject: Petsc with hypre
> Dear,
> I tried to run PETSC with hypre on CrayXT3 system and got the error
> message below. I didn't install PETSC so I don't know whether it was
> installed with hypre option or not. So if I need to install PETSC with
> using hypre option, then please send me the instruction for
> installation (and also using parMeTiS).
> I appreciate your help,
> Regards,
> -hung
> hvnguyen:sapphire09% yod -np 16 ./fw -ksp_type richardson -pc_type
> hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_max_iter 4
> -pc_hypre_boomeramg_tol 1.0e-15
> [10]PETSC ERROR: [9]PETSC ERROR: [13]PETSC ERROR: [11]PETSC ERROR:
> [3]PETSC
> ERROR: [2]PETSC ERROR: [8]PETSC ERROR: [7]PETSC ERROR: [14]PETSC
> ERROR:
> [0]PETSC ERROR: [5]PETSC ERROR: [12]PETSC ERROR: [15]PETSC ERROR:
> [6]PETSC
> ERROR: [1]PETSC ERROR: [4]PETSC ERROR: --------------------- Error
> Message
> --------------------- Error Message
> [3]PETSC
> ERROR:
> [6]PETSC
> ERROR: [1]PETSC ERROR: [4]PETSC ERROR: Unknown type. Check for miss-
> spelling
> or missing external package needed for type!
> Unknown type. Check for miss-spelling or missing external package
> needed for
> type!
> needed for
> type!
> needed for
> type!
> [3]PETSC
> ERROR:
> [6]PETSC
> ERROR: [1]PETSC ERROR: [4]PETSC ERROR: Unable to find requested PC
> type
> hypre!
> Unable to find requested PC type hypre!
> [3]PETSC
> ERROR:
> [6]PETSC
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080801/22bb0561/attachment.htm>
