Question on using MUMPS in PETSC
Hong Zhang
hzhang at mcs.anl.gov
Fri Aug 1 09:30:07 CDT 2008
Randy,
The petsc interface does not create much of extra
memories.
The analysis phase of MUMPS solver is sequential -
which might causes one process blow up with memory.
I'm forwarding this email to the mumps developer
for their input.
Jean-Yves,
What do you think about the reported problem
(see attached below)?
Hong
On Thu, 31 Jul 2008, Randall Mackie wrote:
> Barry,
> I don't think it's the matrix - I saw the same behavior when I ran your
> ex2.c program and set m=n=5000.
> Randy
> Barry Smith wrote:
>> If m and n are the number of rows and columns of the sparse matrix (i.e.
>> it is
>> tiny problem) then please
>> send us matrix so we can experiment with it to petsc-maint at mcs.anl.log
>> You can send us the matrix by simply running with -ksp_view_binary and
>> sending us the file binaryoutput.
>> Barry
>> On Jul 31, 2008, at 5:56 PM, Randall Mackie wrote:
>>> When m = n = small (like 50), it works fine. When I set m=n=5000, I see
>>> the same thing, where one process on the localhost is taking >4 G of RAM,
>>> while all other processes are taking 137 M.
>>> Is this the standard behavior for MUMPS? It seems strange to me.
>>> Randy
>>> Matthew Knepley wrote:
>>>> Does it work on KSP ex2?
>>>> Matt
>>>> On Thu, Jul 31, 2008 at 4:35 PM, Randall Mackie <rlmackie862 at gmail.com>
>>>> wrote:
>>>>> I've compiled PETSc with MUMPS support, and I'm trying to run a small
>>>>> test
>>>>> problem, but I'm having some problems. It seems to begin just fine, but
>>>>> what I notice is that on one process (out of 64), the memory just keeps
>>>>> going up and up and up until it crashes, while on the other processes,
>>>>> the memory usage is reasonable. I'm wondering if anyone might have any
>>>>> idea
>>>>> why? By the way, my command file is like this:
>>>>> -ksp_type preonly
>>>>> -pc_type lu
>>>>> -mat_type aijmumps
>>>>> -mat_mumps_cntl_4 3
>>>>> -mat_mumps_cntl_9 1
>>>>> Randy
>>>>> ps. This happens after the analysis stage and in the factorization
>>>>> stage.
