Compiled information for Petsc 2.3.2-p10
    Mads Hoel
    mfhoel at ifi.uio.no
    Wed Oct 10 13:34:48 CDT 2007
På Wed, 10 Oct 2007 02:41:22 +0200, skrev Barry Smith <bsmith at mcs.anl.gov>:
Hi all,
"make showlinklibs" does not seem to be defined in the makefile(s). It has
probably been renamed to "make getlinklibs", since that works. Might want
to
check out "make getmpilinklibs" also. They are all defined in
${PETSC_DIR}/bmake/common/rules.
>  Sounds like you are NOT using the handy PETSc makefiles; in the PETSc
> main directory you can do
> make showlinklibs
> and it will show you what libraries you need to list in your makefile
>    Barry
> On Tue, 9 Oct 2007, Trivedi, Jagruti CIV 470000D, 474300D wrote:
>> Barry,
>> When I compile my application it fails with a linking "ld" error that
>> it can not
>> Find -lmpich. With this new install, I have mpich2-1.0.5p4. Where do I
>> change from mpich to mpich2 linking?
>> Thanks,
>> ...Jagruti
>> -----Original Message-----
>> From: owner-petsc-users at mcs.anl.gov
>> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Barry Smith
>> Sent: Tuesday, October 09, 2007 16:47
>> To: petsc-users at mcs.anl.gov
>> Subject: RE: Compiled information for Petsc 2.3.2-p10
>>   Strange, never seen that before. It is likely you can just ignore it.
>>    Barry
>> > Hello Licendro,
>> > Here is the first question after the installation of petsc-2.3.3-p6.
>> > I ran:
>> > Config/config.py --with-cc=gcc --with-fc=g77
>> > --download-f-blas-lapack=1 --download-mpich=1
>> > /usr/local/bin/make all test /* run gnu make
>> > I get the following status error:
>> > Running test examples to verify correct installation c/C++ example
>> > src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
>> > c/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
>> > MPI process
>> > Graphics example src/snes/examples/tutorials/ex19 run successfully
>> > with 1 MPI process
>> > /bin/sh: test: argument expected
>> >  make[3]: [ex19.rm] Error 1 (ignored)
>> > Fortran example src/snes/examples/tutorials/ex5f run successfully with
>> > 1 MPI process
>> >  make[3]: [ex5f.rm] Error 1 (ignored)
>> > Completed test examples
>> > Is this the correct installation? Why am I getting this error
>> messages?
>> > Thanks,
>> > ....Jagruti
>> > [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Lisandro Dalcin
>> > Sent: Tuesday, October 09, 2007 12:31
>> > Subject: Re: Compiled information for Petsc 2.3.2-p10
>> > I want to suggest you to update to 2.3.3. Of course, you have the
>> extra trouble of figuring out yourself the cummulative changes since
>> 2.2.1.
>> > Go ahead updating to 2.3.3, and I can help you at any point you have
>> trouble.
>> > On 10/9/07, Trivedi, Jagruti CIV 470000D, 474300D
>> <jagruti.trivedi at navy.mil> wrote:
>> > > Do you mean that I should apply changes from 2.2.1 to 2.3.0 and then
>> > > 2.3.1 and so forth until I come upto 2.3.3 version or I can apply
>> > > directly from 2.2.1 to 2.3.3?
>> > > ...Jagruti
>> > > [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
>> > > Sent: Tuesday, October 09, 2007 11:29
>> > > It is possible that we didn't document all the changes between
>> releases.
>> > > But the recommended approach is to look at changes file for each
>> > > version after 2.2.1 - and apply these changes.
>> > > And if your code is in C - then the compiler will help in finding
>> > > any undocumented changes in prototypes.. etc..
>> > > BTW: the current release version is 2.3.3 [so you might want to
>> > > upgrade to this version instead of 2.3.2]
>> > > Satish
>> > > > Hello there,
>> > > > I am trying to port my application from petsc 2.2.1 to petsc
>> > > 2.3.2-p10.
>> > > > Has anybody compiled
>> > > > The real life changes needed to make other than listed in the
>> > > > changes file?
>> > > > I really appreciate if you have hands on do's and don'ts for
>> > > > porting from petsc-2.2.1 to Petsc 2.3.2-p10.
>> > > > Looking forward to positive replies.
>> > > > Thanks and Best Regards,
>> > > > ....Jagruti
>> > > > NAWC
>> > Lisandro Dalcín
>> > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> > Tel/Fax: +54-(0)342-451.1594
Mads Hoel
