Help: The SNES test result of my jacobian matrix
Fri Nov 30 08:10:36 CST 2007
    The testing of the Jacobian is done for three different input
vectors.
Since the first number is fairly large this indicates the Jacobian
computed
is not correct. You can run with -snes_test_display ALSO and it will
show
you both your Jacobian and the one computed with differencing so you
can see exactly what entries are wrong.
    Good luck,
    Barry
On Nov 30, 2007, at 3:09 AM, Gong Ding wrote:
> Hi all,
> I use -snes_type test to check the Jacobian matrix of my
> semiconductor code.
> And get the result as follows:
> Testing hand-coded Jacobian, if the ratio is
> O(1.e-8), the hand-coded Jacobian is probably correct.
> Run with -snes_test_display to show difference
> of hand-coded and finite difference Jacobian.
> Norm of matrix ratio 0.00277812 difference 0.0152703
> Norm of matrix ratio 1.82658e-09 difference 1.01895e-08
> Norm of matrix ratio 1.82964e-09 difference 1.02066e-08
> [0]PETSC ERROR: SNESSolve() line 1871 in src/snes/interface/snes.c
> It seems PETSC check hand writing Jacobian for 3 times.
> The Norm is something large in the first time check but keeps small
> in other two.
> Dose this mean my Jacobian implementation correct or not?
> However, my code seems work well.
> Yours
> GONG DING
> Last mail seems lost. I send it again.
