Zero Pivot Row in LU Factorization
Sun Nov 25 18:15:17 CST 2007
   KSP *subksp;
    KSPGetPC(ksp,pc)
    PCBJacobiGetSubKSP(pc,&n,PETSC_NULL,&subksp)
    KSPGetPC(subksp[0],&subpc);
    PCFactorSetxxxxxx(subpc, ....
   Barry
On Nov 25, 2007, at 1:10 PM, Tim Stitt wrote:
> I should also add that the code executes without this error when
> using 1 processor...but then displays the error when running in
> parallel with more than one process.
> Tim Stitt wrote:
>> Hi all,
>> Can anyone suggest ways of overcoming the following pivot error I
>> keep receiving in my PETSc code during a KSPSolve().
>> [1]PETSC ERROR: Detected zero pivot in LU factorization
>> see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot
>> [1]PETSC ERROR: Zero pivot row 1801 value 0.00102826 tolerance
>> 0.00165189 * rowsum 1.65189e+09!
>> From checking the documentation....the error is in row 1801, which
>> means it is most likely not a matrix assembly issue?
>> I tried the following prior to the solve with no luck either.....
>> call KSPGetPC(ksp,pc,error)
>> call PCFactorSetShiftNonzero(pc,PETSC_DECIDE,error)
>> Is there anything else I can try?
>> Thanks,
>> Tim.
> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> HPC Application Consultant - ICHEC (www.ichec.ie)
> Dublin Institute for Advanced Studies
> 5 Merrion Square - Dublin 2 - Ireland
> +353-1-6621333 (tel) / +353-1-6621477 (fax)
