dropping columns/rows from matrix?
Barry Smith
bsmith at mcs.anl.gov
Fri Nov 23 20:38:52 CST 2007
On Nov 23, 2007, at 8:13 PM, Peter Schröder wrote:
> Barry Smith wrote:
>> We use MatGetSubMatrix() to do this. Rather than dropping/adding
>> rows and columns just grab the
>> part you want and use it then destroy it and grab another part you
>> want. We've done this with active set
>> methods and the time to do the MatGetSubMatrix() has been
>> surprisingly small percentage of the time.
> Aaaah. Ok. Even if the submatrix is everyone but one column/row?
> Very well.
Yup :-). Only a couple of percent of the active set solver was
spent in the GetSubMatrix()
> The one other way I had thought might be to fix one of the variables
> (some entry of the x vector is forced to zero) and ignore the
> corresponding part of the residual. But this may be too hacky an
> approach given the overall structure of Petsc.
> I'll use MatGetSubMatrix() for now.
> peter
