pc_factor_fill
Waad Subber
w_subber at yahoo.com
Thu Nov 22 19:29:04 CST 2007
Thank you Barry :o)
Waad
Barry Smith <bsmith at mcs.anl.gov> wrote:
If you are using KSP then you should NEVER call MatGetInfo(), MatLUFactor....just call the PCFactorSetFill(). If you are not using the KSP then
you need to declare a MatFactorInfo and fill it up the way you want.
Note that MatInfo is different from MatFactorInfo you need to set the value
in MatFactorInfo that you pass to the factorization routines.
Barry
On Nov 22, 2007, at 12:55 PM, Waad Subber wrote:
Thanks Barry
One more question please:
Should I get and set the fill factor like this:
call MatGetInfo(A,MAT_LOCAL,info,ierr)
FACTFILL = info(MAT_INFO_fill_ratio_needed)
call PCFactorSetFill(pc,FACTFILL,ierr)
call ISSetPermutation(indexSet,IERR);CHKERRQ(IERR)
call MatLUFactorSymbolic(A,indexSet,indexSet,FACTFILL,...
call MatLUFactorNumeric(A,FACTFILL,factorMat,IERR)
Thanks
Waad
PCFactorSetFill() after calling KSPSetPC()
Barry
If you are using multiple different KSP's you might look at KSPSetOptionsPrefix()
to allow using command line options to set different values for different solvers.
On Nov 22, 2007, at 5:46 AM, Waad Subber wrote:
Hello PETSc Users,
I have a serial code to solve multiple matrices. I am using LU factorization. When I run the code with the (-info) option, it gives me different values for (pc_factor_fill) depending on the input matrix. I am wondering if I can set these values for the (pc_factor_fill) inside the code instead of running it with runtime option, for it is one code with multiple inputs.
Thanks a lot
Waad
For Matrix No.1
[5] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 2.96
[5] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.96 or use
[5] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.96);
[5] MatLUFactorSymbolic_SeqAIJ(): for best performance.
For Matrix No.2
[9] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 2.42069
[9] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 2.42069 or use
[9] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,2.42069);
[9] MatLUFactorSymbolic_SeqAIJ(): for best performance.
For Matrix No. n
[8] MatLUFactorSymbolic_SeqAIJ(): Reallocs 3 Fill ratio:given 0 needed 1.87742
[8] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 1.87742 or use
[8] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,1.87742);
[8] MatLUFactorSymbolic_SeqAIJ(): for best performance.
Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now.
Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how.
Never miss a thing. Make Yahoo your homepage.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20071122/141b48aa/attachment.htm>
