Dual core performance estimate
Aron Ahmadia
aja2111 at columbia.edu
Sun Nov 18 14:53:13 CST 2007
Hi Ben,
You're asking a question that is very specific to the program you're
running. I think the general consensus on this list has been that for
the more common uses of PETSc, getting dual-cores will not speed up
your performance as much as dual-processors. For OS X, dual-cores are
pretty much the baseline now, so I wouldn't worry too much about it.
~A
On Nov 18, 2007 3:34 PM, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> someone was talking abt core 2 duo performance on os x in some previous
> email. it seems that due to memory issues, it's not possible to get 2x the
> performance. there's also some mention of amd vs intel dual core.
> for computation using PETSc, is there any reason to buy one instead of the
> other? Also, supposed I use winxp + mpich2 + PETSc on a dual core, what sort
> of performance increase can we expect as compared to PETSc + nompi on the
> same machine?
> or is that too difficult an answer to give since there are too many factors?
> thank you
> regards
