problem compiling PETSC on MacOS Leopard
Bernard Knaepen bknaepen at ulb.ac.be
Sun Nov 18 03:32:23 CST 2007
Hello,
I would like to compile PETSC on Leopard but I am encountering a
problem during configuration. The scripts stops with:
dolfin:petsc-2.3.3-p8 bknaepen$ ./config/configure.py --with-cc=mpicc
--with-fc=mpif90 --with-cxx=mpicxx
              Configuring PETSc to compile on your system
TESTING: checkFortranCompiler from config.setCompilers(python/
BuildSystem/config/setCompilers.py:
708
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Fortran compiler you provided with --with-fc=mpif90 does not work
My MPI installation is mpich2 1.0.6p1 and I have the latest ifort
compiler installed (10.0.20). I have test mpif90 and it is working ok.
I copy below the configure.log file.
Any help would be appreciated, thanks,
Bernard.
                             Pushing language C
                             Popping language C
                             Pushing language Cxx
                             Popping language Cxx
                             Pushing language FC
                             Popping language FC
sh: /bin/sh /Users/bknaepen/Unix/petsc-2.3.3-p8/python/BuildSystem/
config/packages/config.guess
Executing: /bin/sh /Users/bknaepen/Unix/petsc-2.3.3-p8/python/
BuildSystem/config/packages/config.guess
sh: i686-apple-darwin9.1.0
config/packages/config.sub i686-apple-darwin9.1.0
BuildSystem/config/packages/config.sub i686-apple-darwin9.1.0
Starting Configure Run at Sun Nov 18 10:29:29 2007
Configure Options: --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpicxx
--with-shared=0 --configModules=PETSc.Configure --
optionsModule=PETSc.compilerOptions
Working directory: /Users/bknaepen/Unix/petsc-2.3.3-p8
Python version:
2.5.1 (r251:54863, Oct  5 2007, 21:08:09)
[GCC 4.0.1 (Apple Inc. build 5465)]
         Pushing language C
         Popping language C
         Pushing language FC
         Popping language FC
TEST configureExternalPackagesDir from config.framework(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/BuildSystem/config/framework.py:807)
TESTING: configureExternalPackagesDir from config.framework(python/
TEST configureLibrary from PETSc.packages.PVODE(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/PETSc/packages/PVODE.py:10)
TESTING: configureLibrary from PETSc.packages.PVODE(python/PETSc/
   Find a PVODE installation and check if it can work with PETSc
TEST configureLibrary from PETSc.packages.NetCDF(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/PETSc/packages/NetCDF.py:10)
TESTING: configureLibrary from PETSc.packages.NetCDF(python/PETSc/
   Find a NetCDF installation and check if it can work with PETSc
TEST configureMercurial from config.sourceControl(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/sourceControl.py:23)
TESTING: configureMercurial from config.sourceControl(python/
   Find the Mercurial executable
Checking for program /opt/intel/fc/10.0.020/bin/hg...not found
Checking for program /usr/X11R6/bin/hg...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/hg...not found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/hg...not found
Checking for program /bin/hg...not found
Checking for program /sbin/hg...not found
Checking for program /usr/bin/hg...not found
Checking for program /usr/sbin/hg...not found
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/texbin/hg...not found
Checking for program /Users/bknaepen/hg...not found
TEST configureCVS from config.sourceControl(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/sourceControl.py:30)
TESTING: configureCVS from config.sourceControl(python/BuildSystem/
   Find the CVS executable
Checking for program /opt/intel/fc/10.0.020/bin/cvs...not found
Checking for program /usr/X11R6/bin/cvs...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/cvs...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/cvs...not found
Checking for program /bin/cvs...not found
Checking for program /sbin/cvs...not found
Checking for program /usr/bin/cvs...found
           Defined make macro "CVS" to "cvs"
TEST configureSubversion from config.sourceControl(/Users/bknaepen/
Unix/petsc-2.3.3-p8/python/BuildSystem/config/sourceControl.py:35)
TESTING: configureSubversion from config.sourceControl(python/
   Find the Subversion executable
Checking for program /opt/intel/fc/10.0.020/bin/svn...not found
Checking for program /usr/X11R6/bin/svn...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/svn...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/svn...not found
Checking for program /bin/svn...not found
Checking for program /sbin/svn...not found
Checking for program /usr/bin/svn...found
           Defined make macro "SVN" to "svn"
TEST configureMkdir from config.programs(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/programs.py:21)
TESTING: configureMkdir from config.programs(python/BuildSystem/config/
programs.py:21)
   Make sure we can have mkdir automatically make intermediate
directories
Checking for program /opt/intel/fc/10.0.020/bin/mkdir...not found
Checking for program /usr/X11R6/bin/mkdir...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/mkdir...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/mkdir...not
found
Checking for program /bin/mkdir...found
sh: /bin/mkdir -p .conftest/tmp
Executing: /bin/mkdir -p .conftest/tmp
sh:
       Adding -p flag to /bin/mkdir -p to automatically create
directories
         Defined make macro "MKDIR" to "/bin/mkdir -p"
TEST configurePrograms from config.programs(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/programs.py:43)
TESTING: configurePrograms from config.programs(python/BuildSystem/
   Check for the programs needed to build and run PETSc
Checking for program /opt/intel/fc/10.0.020/bin/sh...not found
Checking for program /usr/X11R6/bin/sh...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/sh...not found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/sh...not found
Checking for program /bin/sh...found
           Defined make macro "SHELL" to "/bin/sh"
Checking for program /opt/intel/fc/10.0.020/bin/sed...not found
Checking for program /usr/X11R6/bin/sed...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/sed...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/sed...not found
Checking for program /bin/sed...not found
Checking for program /sbin/sed...not found
Checking for program /usr/bin/sed...found
           Defined make macro "SED" to "/usr/bin/sed"
Checking for program /opt/intel/fc/10.0.020/bin/mv...not found
Checking for program /usr/X11R6/bin/mv...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/mv...not found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/mv...not found
Checking for program /bin/mv...found
           Defined make macro "MV" to "/bin/mv"
Checking for program /opt/intel/fc/10.0.020/bin/cp...not found
Checking for program /usr/X11R6/bin/cp...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/cp...not found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/cp...not found
Checking for program /bin/cp...found
           Defined make macro "CP" to "/bin/cp"
Checking for program /opt/intel/fc/10.0.020/bin/grep...not found
Checking for program /usr/X11R6/bin/grep...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/grep...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/grep...not
found
Checking for program /bin/grep...not found
Checking for program /sbin/grep...not found
Checking for program /usr/bin/grep...found
           Defined make macro "GREP" to "/usr/bin/grep"
Checking for program /opt/intel/fc/10.0.020/bin/rm...not found
Checking for program /usr/X11R6/bin/rm...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/rm...not found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/rm...not found
Checking for program /bin/rm...found
           Defined make macro "RM" to "/bin/rm -f"
Checking for program /opt/intel/fc/10.0.020/bin/diff...not found
Checking for program /usr/X11R6/bin/diff...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/diff...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/diff...not
found
Checking for program /bin/diff...not found
Checking for program /sbin/diff...not found
Checking for program /usr/bin/diff...found
sh: /usr/bin/diff -w diff1 diff2
Executing: /usr/bin/diff -w diff1 diff2
sh:
         Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /Users/bknaepen/ps...not found
Checking for program /opt/intel/fc/10.0.020/bin/gzip...not found
Checking for program /usr/X11R6/bin/gzip...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/gzip...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/gzip...not
found
Checking for program /bin/gzip...not found
Checking for program /sbin/gzip...not found
Checking for program /usr/bin/gzip...found
           Defined make macro "GZIP" to "/usr/bin/gzip"
         Defined "HAVE_GZIP" to "1"
TEST configureMake from PETSc.utilities.Make(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/PETSc/utilities/Make.py:21)
TESTING: configureMake from PETSc.utilities.Make(python/PETSc/
   Check various things about make
Checking for program /opt/intel/fc/10.0.020/bin/make...not found
Checking for program /usr/X11R6/bin/make...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/make...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/make...not
found
Checking for program /bin/make...not found
Checking for program /sbin/make...not found
Checking for program /usr/bin/make...found
           Defined make macro "MAKE" to "/usr/bin/make"
sh: strings /usr/bin/make
Executing: strings /usr/bin/make
sh: attempt to use unsupported feature: `%s'
touch: Archive `%s' does not exist
touch: `%s' is not a valid archive
touch:
touch: Member `%s' does not exist in `%s'
touch: Bad return code from ar_member_touch on `%s'
!<arch>
ARFILENAMES/
$(MAKE)
${MAKE}
*** [%s] Archive member `%s' may be bogus; not deleted
*** Archive member `%s' may be bogus; not deleted
*** [%s] Deleting file `%s'
*** Deleting file `%s'
unlink:
kill
#  commands to execute
  (built-in):
  (from `%s', line %lu):
%.*s
GNUMAKE
MAKEFILEPATH
$(NEXT_ROOT)/Developer/Makefiles
CHECKOUT,v
+$(if $(wildcard $@),,$(CO) $(COFLAGS) $< $@)
COFL...
... h:
can't allocate %ld bytes for hash table: memory exhausted
Load=%ld/%ld=%.0f%%,
Rehash=%d,
Collisions=%ld/%ld=%.0f%%
$(VPATH)
Can't do VPATH expansion on a null file.
Using old-style VPATH substitution.
Consider using automatic variable substitution instead.
glob
next != NULL
/SourceCache/gnumake/gnumake-119/make/glob/glob.c
alnum
alpha
blank
cntrl
digit
graph
lower
print
punct
space
upper
xdigit
.out
  .a
  .ln
  .o
  .c
  .cc
  .C
  .cpp
  .p
  .f
  .F
  .m
  .r
  .y
  .l
  .ym
  .lm
  .s
  .S
  .mod
  .sym
  .def
  .h .info .dvi .tex .texinfo .texi .txinfo .w .ch .web .sh .elc .el
/bin/sh
         Defined make macro "OMAKE " to "/usr/bin/make  --no-print-
directory"
         Defined make rule "libc" with dependencies "${LIBNAME}($
{OBJSC} ${SOBJSC})" and code []
         Defined make rule "libf" with dependencies "${OBJSF}" and
code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureDebuggers from PETSc.utilities.debuggers(/Users/bknaepen/
Unix/petsc-2.3.3-p8/python/PETSc/utilities/debuggers.py:22)
TESTING: configureDebuggers from PETSc.utilities.debuggers(python/
   Find a default debugger and determine its arguments
Checking for program /opt/intel/fc/10.0.020/bin/gdb...not found
Checking for program /usr/X11R6/bin/gdb...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/gdb...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/gdb...not found
Checking for program /bin/gdb...not found
Checking for program /sbin/gdb...not found
Checking for program /usr/bin/gdb...found
           Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /opt/intel/fc/10.0.020/bin/dbx...not found
Checking for program /usr/X11R6/bin/dbx...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/dbx...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /sbin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /usr/sbin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/texbin/dbx...not found
Checking for program /Users/bknaepen/dbx...not found
Checking for program /opt/intel/fc/10.0.020/bin/xdb...not found
Checking for program /usr/X11R6/bin/xdb...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/xdb...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /sbin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /usr/sbin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/texbin/xdb...not found
Checking for program /Users/bknaepen/xdb...not found
         Defined "USE_GDB_DEBUGGER" to "1"
TEST configureCLanguage from PETSc.utilities.languages(/Users/bknaepen/
Unix/petsc-2.3.3-p8/python/PETSc/utilities/languages.py:43)
TESTING: configureCLanguage from PETSc.utilities.languages(python/
   Choose between C and C++ bindings
TEST configureLanguageSupport from PETSc.utilities.languages(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/PETSc/utilities/languages.py:49)
TESTING: configureLanguageSupport from
PETSc.utilities.languages(python/PETSc/utilities/languages.py:49)
   Check c-support c++-support and other misc tests
       Turning off C++ support
       Allowing C++ name mangling
       C language is C
         Defined "CLANGUAGE_C" to "1"
TEST configureExternC from PETSc.utilities.languages(/Users/bknaepen/
Unix/petsc-2.3.3-p8/python/PETSc/utilities/languages.py:66)
TESTING: configureExternC from PETSc.utilities.languages(python/PETSc/
   Protect C bindings from C++ mangling
         Defined "USE_EXTERN_CXX" to " "
TEST configureFortranLanguage from PETSc.utilities.languages(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/PETSc/utilities/languages.py:72)
TESTING: configureFortranLanguage from
PETSc.utilities.languages(python/PETSc/utilities/languages.py:72)
   Turn on Fortran bindings
       Using Fortran
TEST configureDirectories from PETSc.utilities.petscdir(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/PETSc/utilities/petscdir.py:34)
TESTING: configureDirectories from PETSc.utilities.petscdir(python/
   Checks PETSC_DIR and sets if not set
       Version Information:
       #define PETSC_VERSION_RELEASE    1
       #define PETSC_VERSION_MAJOR      2
       #define PETSC_VERSION_MINOR      3
       #define PETSC_VERSION_SUBMINOR   3
       #define PETSC_VERSION_PATCH      8
       #define PETSC_VERSION_DATE       "May, 23, 2007"
       #define PETSC_VERSION_PATCH_DATE "Fri Nov 16 17:03:40 CST 2007"
       #define PETSC_VERSION_HG
"414581156e67e55c761739b0deb119f7590d0f4b"
         Defined make macro "DIR" to "/Users/bknaepen/Unix/petsc-2.3.3-
p8"
         Defined "DIR" to "/Users/bknaepen/Unix/petsc-2.3.3-p8"
sh: /bin/sh /Users/bknaepen/Unix/petsc-2.3.3-p8/bin/config/config.guess
Executing: /bin/sh /Users/bknaepen/Unix/petsc-2.3.3-p8/bin/config/
config.guess
sh: /bin/sh /Users/bknaepen/Unix/petsc-2.3.3-p8/bin/config/config.sub
TEST configureExternalPackagesDir from PETSc.utilities.petscdir(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/PETSc/utilities/petscdir.py:112)
PETSc.utilities.petscdir(python/PETSc/utilities/petscdir.py:112)
TEST configureInstallationMethod from PETSc.utilities.petscdir(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/PETSc/utilities/petscdir.py:119)
TESTING: configureInstallationMethod from
PETSc.utilities.petscdir(python/PETSc/utilities/petscdir.py:119)
       This is a tarball installation
TEST configureETags from PETSc.utilities.Etags(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/PETSc/utilities/Etags.py:27)
TESTING: configureETags from PETSc.utilities.Etags(python/PETSc/
   Determine if etags files exist and try to create otherwise
Found etags file
TEST getDatafilespath from PETSc.utilities.dataFilesPath(/Users/
bknaepen/Unix/petsc-2.3.3-p8/python/PETSc/utilities/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.utilities.dataFilesPath(python/
   Checks what DATAFILESPATH should be
         Defined make macro "DATAFILESPATH" to "None"
TEST checkVendor from config.setCompilers(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/setCompilers.py:262)
TESTING: checkVendor from config.setCompilers(python/BuildSystem/
   Determine the compiler vendor
       Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/setCompilers.py:272)
TESTING: checkInitialFlags from config.setCompilers(python/BuildSystem/
   Initialize the compiler and linker flags
         Pushing language C
       Initialized CFLAGS to
       Initialized LDFLAGS to
         Popping language C
       Initialized CXXFLAGS to
       Initialized CXX_CXXFLAGS to
         Pushing language FC
       Initialized FFLAGS to
         Popping language FC
       Initialized CPPFLAGS to
       Initialized executableFlags to []
       Initialized sharedLibraryFlags to []
       Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/setCompilers.py:380)
TESTING: checkCCompiler from config.setCompilers(python/BuildSystem/
   Locate a functional C compiler
Checking for program /opt/intel/fc/10.0.020/bin/mpicc...not found
Checking for program /usr/X11R6/bin/mpicc...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/mpicc...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/mpicc...found
           Defined make macro "CC" to "mpicc"
           Pushing language C
sh: mpicc -c -o conftest.o   conftest.c
Executing: mpicc -c -o conftest.o   conftest.c
sh:
sh:
                                           Pushing language C
                                           Popping language C
                                           Pushing language FC
                                           Popping language FC
                   Pushing language C
                   Popping language C
sh: mpicc  -o conftest     conftest.o
Executing: mpicc  -o conftest     conftest.o
sh:
sh:
                       Pushing language C
                       Popping language C
sh:
Executing: ./conftest
sh: ./conftest
sh:
           Popping language C
TEST checkCPreprocessor from config.setCompilers(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/setCompilers.py:437)
TESTING: checkCPreprocessor from config.setCompilers(python/
   Locate a functional C preprocessor
found
           Defined make macro "CPP" to "mpicc -E"
         Pushing language C
sh: mpicc -E   conftest.c
Executing: mpicc -E   conftest.c
sh: # 1 "conftest.c"
# 1 "<built-in>"
# 1 "<command line>"
# 1 "conftest.c"
# 1 "confdefs.h" 1
# 2 "conftest.c" 2
# 1 "conffix.h" 1
# 3 "conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/available.h" 1 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 34 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/inc...
...  size_t, size_t,
      int (*)(const void *, const void *));
void qsort_r(void *, size_t, size_t, void *,
      int (*)(void *, const void *, const void *));
int radixsort(const unsigned char **, int, const unsigned char *,
      unsigned);
void setprogname(const char *);
int sradixsort(const unsigned char **, int, const unsigned char *,
      unsigned);
void sranddev(void);
void srandomdev(void);
void *reallocf(void *, size_t);
long long
   strtoq(const char *, char **, int);
unsigned long long
   strtouq(const char *, char **, int);
extern char *suboptarg;
void *valloc(size_t);
# 3 "conftest.c" 2
         Popping language C
TEST checkCxxCompiler from config.setCompilers(/Users/bknaepen/Unix/
petsc-2.3.3-p8/python/BuildSystem/config/setCompilers.py:541)
TESTING: checkCxxCompiler from config.setCompilers(python/BuildSystem/
   Locate a functional Cxx compiler
TEST checkFortranCompiler from config.setCompilers(/Users/bknaepen/
Unix/petsc-2.3.3-p8/python/BuildSystem/config/setCompilers.py:708)
   Locate a functional Fortran compiler
Checking for program /opt/intel/fc/10.0.020/bin/mpif90...not found
Checking for program /usr/X11R6/bin/mpif90...not found
Checking for program /opt/toolworks/totalview.8.3.0-0/bin/mpif90...not
found
Checking for program /Users/bknaepen/Unix/mpich2-106/bin/mpif90...found
           Defined make macro "FC" to "mpif90"
           Pushing language FC
sh: mpif90 -c -o conftest.o   conftest.F
Executing: mpif90 -c -o conftest.o   conftest.F
sh:
Possible ERROR while running compiler: ret = 256
error message = {ifort: error #10106: Fatal error in /opt/intel/fc/
10.0.020/bin/fpp, terminated by segmentation violation
Source:
       program main
       end
           Popping language FC
       Error testing Fortran compiler: Cannot compile FC with mpicc.
        MPI installation mpif90 is likely incorrect.
   Use --with-mpi-dir to indicate an alternate MPI.
for details):
   File "./config/configure.py", line 190, in petsc_configure
     framework.configure(out = sys.stdout)
   File "/Users/bknaepen/Unix/petsc-2.3.3-p8/python/BuildSystem/config/
framework.py", line 878, in configure
     child.configure()
setCompilers.py", line 1267, in configure
     self.executeTest(self.checkFortranCompiler)
base.py", line 93, in executeTest
     return apply(test, args,kargs)
setCompilers.py", line 714, in checkFortranCompiler
     for compiler in self.generateFortranCompilerGuesses():
setCompilers.py", line 631, in generateFortranCompilerGuesses
     raise RuntimeError('Fortran compiler you provided with --with-
fc='+self.framework.argDB['with-fc']+' does not work')
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20071118/0b20d767/attachment.pgp>
