not enough memory?!
    Zhifeng Sheng
    z.sheng at ewi.tudelft.nl
    Fri Nov  2 10:04:48 CDT 2007
Hong Zhang wrote:
> k>>>
>> So ... computation of the preconditioner is actually called by
>> KSPSetUp() instead of PCGetFactoredMatrix(prec,&M)?
> Yes.
>> Could you please tell me when the system matrix be factorized
>> (incompletely)? thank you.
> During a call of KSPSetUp().
> Hong
>> Zhifeng
Thank you for your reply, since the problem I have is ICC took too much
memory, but I think I can fix it with reorderring the matrix.
My matrix is SeqSBAIJ and ICC is used as preconditioner, I think the
default orderring is "natural", while I think nested-dissection is what
I need.
However, when I choose nested dissection with -
*pc_factor_mat_ordering_type nd, this is what comes out:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] SPARSEPACKfndsep line 50 src/mat/order/fndsep.c
[0]PETSC ERROR: [0] SPARSEPACKgennd line 70 src/mat/order/gennd.c
[0]PETSC ERROR: [0] MatOrdering_ND line 18 src/mat/order/spnd.c
[0]PETSC ERROR: [0] MatGetOrdering line 187 src/mat/order/sorder.c
[0]PETSC ERROR: [0] PCSetup_ICC line 113 src/ksp/pc/impls/factor/icc/icc.c
[0]PETSC ERROR: [0] PCSetUp line 778 src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPSolve line 305 src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 10, Wed Mar 28
19:13:22 CDT 2007 HG revision: d7298c71db7f5e767f359ae35d33cab3bed44428
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: bin/main on a linux-gnu named callisto by zhifeng Fri
Nov 2 16:00:58 2007
[0]PETSC ERROR: Libraries linked from
/u/01/01/zhifeng/install/lib/linux-gnu-c-debug
[0]PETSC ERROR: Configure run at Wed Aug 8 13:46:26 2007
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
--download-f-blas-lapack=1 --download-mpich=1
--prefix=/u/01/01/zhifeng/install --with-shared=0
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[unset]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
PS: which reorderring schemas are symmetric?
Thanks alot
Best regards
Zhifeng Sheng
