PCFactorSetLevels does not work?!
Zhifeng Sheng z.sheng at ewi.tudelft.nl
Fri Nov 2 07:56:22 CDT 2007
Barry Smith wrote:
>   Are you calling the PCFactorSetLevels() on the prec where the
>ICC is being used. For example if your * below means
>-sub_pc_factor_levels then you need to use
>PCBJacobiGetSubKSP() then get the PC out of that that subksp
>and call the PCFactorSetLevels() on that
>  Barry
>On Wed, 31 Oct 2007, Zhifeng Sheng wrote:
>>Dear all
>>I have a weird problem.
>>In my programme, I try to use ICC(K), while I set the factor level with
>>PCFactorSetLevels(prec, 4);
>>However this does not work.
>>Then I run the executable with the option *-pc_factor_levels 4, it works...
>>Can someone tell me why this is happenning?
>>Thank you
>>Best regards
>>Zhifeng Sheng
Dear all
I figured out the reason .... DO NOT use KSPSetUP() before you
configurate you solver and preconditioners, otherwise, your
configuration shall be ignored.
Best regards
Zhifeng
