Newbie question about synchronization
Satish Balay
balay at mcs.anl.gov
Thu Mar 29 09:51:24 CDT 2007
On Thu, 29 Mar 2007, Knut Erik Teigen wrote:
> On Thu, 2007-03-29 at 03:42 -0400, Diego Nehab wrote:
> > So far, using only one process, everything is simple and
> > works (it took me longer to compile and test MPI and Petsc
> > then to write code that solves my problem :)).
> > When I move to multiple processes, the solver still works, but I
> > couldn't figure out how to select one of the processes to
> > consolidate the solution vector and use it to save a file on disk.
> > I always get an error of the form
> > [0]PETSC ERROR: Argument out of range!
> > [0]PETSC ERROR: Can only get local values, trying xxx!
> > I assume I must bring the solution vector back from the other
> > processes, right?
> > 2) If so, how do I do this?
> If you only want to save the results to disk, you can use the VecView
> function. Just create a viewer, like e.g.
> PetscViewerAsciiOpen(PETSC_COMM_WORLD,"filename",&viewer)
> VecView(solution,viewer)
> You can also output in binary format using BinaryOpen instead. Check the
> chapter on Viewers in the manual.
> If you need to gather the results on one processor for further
> computations, I use standard MPI calls, like this(in Fortran):
> call VecGetArray(sol,sol_ptr,sol_i,ierr)
> ! gather solution on process 0
> if (rank==0) then
> do i=low,high !copy local solution to global solution
> global_sol(i)=sol_ptr(sol_i+i)
> enddo
> do p=1,size-1 !recieve local solution from other processes
> call
> MPI_Recv(local_sol,loc_n,MPI_REAL,p,1,PETSC_COMM_WORLD,istat,mpierr)
> do i=1,loc_n !copy local part to correct position in global
> global_sol(i+high)=local_sol(i)
> high=high+1
> enddo
> enddo
> else
> do j=1,loc_n
> local_sol(j)=sol_ptr(sol_i+j)
> enddo
> call MPI_Send(local_sol,loc_n,MPI_REAL,0,1,PETSC_COMM_WORLD,mpierr)
> endif
> call VecRestoreArray(sol,sol_ptr,sol_i,ierr)
> !copy global solution vector back to grid array
> if (rank==0) then
> do j=1,jmax
> do i=1,imax
> T(i,j)=global_sol((j-1)*imax+i)
> end do
> end do
> endif
> This is probably not the recommended way of doing things. I'm quite new
> at using PETSc myself, so if anyone has a better solution, please
> enlighten me! I should use PETSc data structures for everything, but I'm
> trying to integrate PETSc into already existing code, so it's not that
> easy to do.
VecView() is the correct thing to do for dumping the vec into a file.
However - if you need all the values of the vec on 1 proc - then the
use VecScatterCreateToZero()
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Vec/VecScatterCreateToZero.html
Satish
