SLIM H.A.
h.a.slim at durham.ac.uk
Mon Mar 26 12:36:15 CDT 2007
Dear Satish
This worked now.
./config/configure.py
--with-blas-lapack-lib=\[/usr/local/Cluster-Apps/intel/mkl/8.0/lib/em64t
/libmkl_lapack64.so,libmkl_def.so,libguide.so\]
--with-vendor-compilers=intel --with-gnu-compilers=0
The tests were succesfull with up to two mpi processes. However when I
look into the lib directory there are only static libraries:
hamilton_dcl0has(296)>ls -la lib/linux-gnu-intel
total 27248
drwx------ 2 dcl0has dcl 4096 Mar 26 17:39 ./
drwx------ 4 dcl0has dcl 4096 Mar 23 16:43 ../
-rw------- 1 dcl0has dcl 4394974 Mar 26 17:39 libpetsc.a
-rw------- 1 dcl0has dcl 193378 Mar 26 17:39 libpetsccontrib.a
-rw------- 1 dcl0has dcl 2612462 Mar 26 17:39 libpetscdm.a
-rw------- 1 dcl0has dcl 4525610 Mar 26 17:39 libpetscksp.a
-rw------- 1 dcl0has dcl 10905628 Mar 26 17:39 libpetscmat.a
-rw------- 1 dcl0has dcl 1476668 Mar 26 17:39 libpetscsnes.a
-rw------- 1 dcl0has dcl 685944 Mar 26 17:39 libpetscts.a
-rw------- 1 dcl0has dcl 3025700 Mar 26 17:39 libpetscvec.a
Regards
henk
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: 26 March 2007 17:14
> To: petsc-users at mcs.anl.gov
> Subject: RE:
> With tcsh shell - one has to escape the special chars. [with
> bash the command should work as is].
> i.e
> /lib/em64t/libmkl_lapack64.so\,libmkl_def.so\,libguide.so\]
> Satish
> On Mon, 26 Mar 2007, SLIM H.A. wrote:
> > Thanks
> > I tried
> --with-blas-lapack-lib=[/usr/local/Cluster-Apps/intel/mkl/8.0/lib/em64
> > t/ libmkl_lapack64.so,libmkl_def.so,libguide.so]
> > which gives:
> > ./config/configure.py: No match.
> > I checked that the files
> > exist in /usr/local/Cluster-Apps/intel/mkl/8.0/lib/em64t
> > However I am not familiar with the configure command. Did I use it
> > corrctly?
> > Thanks
> > Henk
> > > Sent: 26 March 2007 16:28
> > > Subject: Re:
> > > Not sure about the binutils stuff - but x86_64 linux
> complains about
> > > using non PIC code in a shared library.
> > > Currently PETSc configure is defaulting to .a version of MKL
> > > - which are incompatible with sharedlibraries. And I'm not sure
> > > what the correct library naems are for the shared version
> of MLK.
> > > You could try using the option:
> > lib/em64t/libmkl_lapack32.so,libmkl_def.so,libguide.so]
> > > or just use --download-f-blas-lapack=1
> > > Satish
> > > On Mon, 26 Mar 2007, Lisandro Dalcin wrote:
> > > > This seems to be a bug of 'binutils' in 64 bits machines.
> > > > http://sources.redhat.com/bugzilla/show_bug.cgi?id=584
> > > > but apparently it was fixed in Feb 2005
> > > > http://sourceware.org/ml/binutils-cvs/2005-02/msg00011.html
> > > > Can you upgrade your 'binutils' package and try what happens?
> > > > On 3/26/07, SLIM H.A. <h.a.slim at durham.ac.uk> wrote:
> > > > > Dear users
> > > > > I want to build petsc with shared object libraries but get
> > > > > errors when building libpetscmat.so and libpetscksp.so I am
> > > using the intel
> > > > > compiler and intel's imkl for lapack/blas
> > > > > Configuration is:
> --with-blas-lapack-dir=/usr/local/Cluster-Apps/intel/mkl/8.0/lib/em6
> > > > > 4t --with-vendor-compilers=intel --with-gnu-compilers=0
> > > > > --with-shared
> > > > > The error is:
> > > > > ld:
> /usr/local/Cluster-Apps/intel/mkl/8.0/lib/em64t/libmkl_lapack.a(dget
> > > > > rf_o
> > > > > mp.o): relocation R_X86_64_PC32 against
> > > > > `_mkl_lapack_dgetrf_omp_271__par_loop0' can not be used
> > > when making
> > > > > a shared object; recompile with -fPIC
> > > > > ld: final link failed: Bad value
> > > > > make[2]: [shared_linux] Error 1 (ignored)
> > > > > Details are in the attached male log file.
> > > > > Thanks for any help
> > > > > Henk
