Help! Installing PETSc?
Bin xubinbin2004 at gmail.com
Wed Mar 14 13:30:50 CDT 2007
 Thanks, it works. But when I try to configure PETSc with --with-shared
> options,
> > config/configure.py \
> >   --with-cc=mpicc \
> >   --with-fc=mpif90 \
> >   --with-mpi-dir=/opt/hpmpi/lib/linux_amd64/ \
> >   --with-mpi-shared=yes \
> >   LIBS=-lpgf90rtl \
> >   --with-debugging=yes \
> >   --download-superlu=no \
> >   --download-superlu_dist=no \
> >   --with-shared
>  I got the following errors:
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.logfor details):
> > C compiler you provided with -with-cc=mpicc does not work
> Do you know why?
> Thank you.
> On 3/14/07, Shaman Mahmoudi <shma7099 at student.uu.se> wrote:
> > Hi,
> > try mpirun -np 1 ./conftest
> > With best regards, Shaman Mahmoudi
> >  On Mar 14, 2007, at 6:56 AM, Bin wrote:
> > mpirun -np 1 conftest
> Yours truly,
> Bin Xu
Yours truly,
Bin Xu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070314/f3e077d3/attachment.htm>
