PETSc CG solver uses more iterations than other CG solver
Lisandro Dalcin
dalcinl at gmail.com
Fri Mar 9 11:05:08 CST 2007
On 3/9/07, Knut Erik Teigen <knutert at stud.ntnu.no> wrote:
> To solve the Navier-Stokes equations, I use an explicit Runge-Kutta
> method with Chorin's projection method,
> so a Poisson equation with von Neumann boundary conditions for the
> pressure has to be solved at every time-step.
All boundary conditions are Neumann type? In that case, please try to
run your program with the following command line option:
-ksp_constant_null_space
and let me know if this corrected your problem.
The equation system is
> positive definite, so I use the CG solver with the ICC preconditioner.
> The problem is that the PETSc solver seems to need a lot more iterations
> to reach the solution than another CG solver I'm using. On a small test
> problem(a rising bubble) with a 60x40 grid, the PETSc solver needs over
> 1000 iterations on average, while the other solver needs less than 100.
> I am using KSPSetInitialGuessNonzero, without this the number of
> iterations is even higher.
> I have also tried applying PETSc to a similar problem, solving the
> Poisson equation with von Neumann boundaries and a forcing function of
> f=sin(pi * x)+sin(pi *y). For this problem, the number of iterations is
> almost exactly the same for PETSc and the other solver.
> Does anyone know what the problem might be? Any help is greatly
> appreciated. I've included the -ksp_view of one of the time steps
> and the -log_summary below.
> Regards,
> Knut Erik Teigen
> MSc student
> Norwegian University of Science and Technology
> Output from -ksp_view:
> KSP Object:
> type: cg
> maximum iterations=10000
> tolerances: relative=1e-06, absolute=1e-50, divergence=10000
> left preconditioning
> PC Object:
> type: icc
> ICC: 0 levels of fill
> ICC: factor fill ratio allocated 1
> ICC: factor fill ratio needed 0.601695
> Factored matrix follows
> Matrix Object:
> type=seqsbaij, rows=2400, cols=2400
> total: nonzeros=7100, allocated nonzeros=7100
> block size is 1
> linear system matrix = precond matrix:
> Matrix Object:
> type=seqaij, rows=2400, cols=2400
> total: nonzeros=11800, allocated nonzeros=12000
> not using I-node routines
> Poisson converged after 1403 iterations
> Output from -log_summary
> ---------------------------------------------- PETSc Performance
> Summary: ----------------------------------------------
> ./run on a gcc-ifc-d named iept0415 with 1 processor, by knutert Fri Mar
> 9 17:06:05 2007
> Using Petsc Release Version 2.3.2, Patch 8, Tue Jan 2 14:33:59 PST 2007
> HG revision: ebeddcedcc065e32fc252af32cf1d01ed4fc7a80
> Max Max/Min Avg Total
> Time (sec): 5.425e+02 1.00000 5.425e+02
> Objects: 7.000e+02 1.00000 7.000e+02
> Flops: 6.744e+10 1.00000 6.744e+10 6.744e+10
> Flops/sec: 1.243e+08 1.00000 1.243e+08 1.243e+08
> Memory: 4.881e+05 1.00000 4.881e+05
> MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
> MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
> MPI Reductions: 1.390e+03 1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> e.g., VecAXPY() for real vectors of length N
> --> 2N flops
> and VecAXPY() for complex vectors of length
> N --> 8N flops
> Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages
> --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total counts %
> Total Avg %Total counts %Total
> 0: Main Stage: 5.4246e+02 100.0% 6.7437e+10 100.0% 0.000e+00
> 0.0% 0.000e+00 0.0% 1.390e+03 100.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
> Count: number of times phase was executed
> Time and Flops/sec: Max - maximum over all processors
> Ratio - ratio of maximum to minimum over all
> processors
> Mess: number of messages sent
> Avg. len: average message length
> Reduct: number of global reductions
> Global: entire computation
> Stage: stages of a computation. Set stages with PetscLogStagePush()
> and PetscLogStagePop().
> %T - percent time in this phase %F - percent flops in this
> phase
> %M - percent messages in this phase %L - percent message
> lengths in this phase
> %R - percent reductions in this phase
> Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> # WARNING!!! #
> # This code was compiled with a debugging option, #
> # To get timing results run config/configure.py #
> # using --with-debugging=no, the performance will #
> # be generally two or three times faster. #
> # WARNING!!! #
> # This code was run without the PreLoadBegin() #
> # macros. To get timing results we always recommend #
> # preloading. otherwise timing numbers may be #
> # meaningless. #
> Event Count Time (sec) Flops/sec
> --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecDot 1668318 1.0 1.9186e+01 1.0 4.17e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 4 12 0 0 0 4 12 0 0 0 417
> VecNorm 835191 1.0 1.0935e+01 1.0 3.67e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 2 6 0 0 0 2 6 0 0 0 367
> VecCopy 688 1.0 1.6126e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecAXPY 1667630 1.0 2.4141e+01 1.0 3.32e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 4 12 0 0 0 4 12 0 0 0 332
> VecAYPX 833815 1.0 1.9062e+01 1.0 2.10e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 4 6 0 0 0 4 6 0 0 0 210
> VecAssemblyBegin 688 1.0 8.5354e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd 688 1.0 7.8177e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMult 834503 1.0 1.5044e+02 1.0 1.18e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 28 26 0 0 0 28 26 0 0 0 118
> MatSolve 835191 1.0 1.8130e+02 1.0 1.42e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 33 38 0 0 0 33 38 0 0 0 142
> MatCholFctrNum 1 1.0 1.1630e-03 1.0 2.06e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 2
> MatICCFactorSym 1 1.0 2.9588e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatAssemblyBegin 688 1.0 2.6343e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd 688 1.0 1.0964e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering 1 1.0 2.6798e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSetup 1 1.0 2.7585e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
> KSPSolve 688 1.0 4.2809e+02 1.0 1.58e+08 1.0 0.0e+00 0.0e+00
> 1.4e+03 79100 0 0100 79100 0 0100 158
> PCSetUp 1 1.0 1.7900e-03 1.0 1.34e+06 1.0 0.0e+00 0.0e+00
> 4.0e+00 0 0 0 0 0 0 0 0 0 0 1
> PCApply 835191 1.0 1.8864e+02 1.0 1.36e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 35 38 0 0 0 35 38 0 0 0 136
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants'
> Mem.
> Index Set 2 2 19640 0
> Vec 694 693 299376 0
> Matrix 2 2 56400 0
> Krylov Solver 1 1 36 0
> Preconditioner 1 1 108 0
> Average time to get PetscTime(): 2.86102e-07
> OptionTable: -ksp_type cg
> OptionTable: -log_summary -ksp_view
> OptionTable: -pc_type icc
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4
> sizeof(PetscScalar) 8
> Configure run at: Thu Mar 8 11:54:22 2007
> Configure options: --with-cc=gcc --with-fc=ifort
> --download-f-blas-lapack=1 --download-mpich=1 --with-debugging=1
> --with-shared=0
> Libraries compiled on Thu Mar 8 12:08:22 CET 2007 on iept0415
> Machine characteristics: Linux iept0415 2.6.16.21-0.8-default #1 Mon Jul
> 3 18:25:39 UTC 2006 i686 i686 i386 GNU/Linux
> Using PETSc directory: /opt/petsc-2.3.2-p8
> Using PETSc arch: gcc-ifc-debug
> Using C compiler: gcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
> -g3
> Using Fortran compiler: ifort -fPIC -g
> Using include paths: -I/opt/petsc-2.3.2-p8
> -I/opt/petsc-2.3.2-p8/bmake/gcc-ifc-debug -I/opt/petsc-2.3.2-p8/include
> -I/opt/petsc-2.3.2-p8/externalpackages/mpich2-1.0.4p1/gcc-ifc-debug/include -I/usr/X11R6/include
> Using C linker: gcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3
> Using Fortran linker: ifort -fPIC -g
> Using libraries: -Wl,-rpath,/opt/petsc-2.3.2-p8/lib/gcc-ifc-debug
> -L/opt/petsc-2.3.2-p8/lib/gcc-ifc-debug -lpetscts -lpetscsnes -lpetscksp
> -lpetscdm -lpetscmat -lpetscvec -lpetsc
> -Wl,-rpath,/opt/petsc-2.3.2-p8/externalpackages/mpich2-1.0.4p1/gcc-ifc-debug/lib -L/opt/petsc-2.3.2-p8/externalpackages/mpich2-1.0.4p1/gcc-ifc-debug/lib -lmpich -lnsl -lrt -L/usr/X11R6/lib -lX11 -Wl,-rpath,/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -L/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -lflapack -Wl,-rpath,/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -L/opt/petsc-2.3.2-p8/externalpackages/fblaslapack/gcc-ifc-debug -lfblas -lm -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -L/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -ldl -lgcc_s -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i5!
> 86-suse-linux/4.1.0/../../.. -Wl,-rpath,/opt/intel/fc/9.1.036/lib -L/opt/intel/fc/9.1.036/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/ -L/usr/lib/gcc/i586-suse-linux/4.1.0/ -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../ -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../../ -lifport -lifcore -limf -lm -lipgo -lirc -lirc_s -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -lm -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0 -L/usr/lib/gcc/i586-suse-linux/4.1.0 -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../../../i586-suse-linux/lib -Wl,-rpath,/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -L/usr/lib/gcc/i586-suse-linux/4.1.0/../../.. -ldl -lgcc_s -ldl
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
