Using compaq visual fortran with gcc to compile PETSc
Mon Mar 5 11:13:59 CST 2007
On Mon, 5 Mar 2007, Ben Tay wrote:
> Hi,
> I'm using compaq visual fortran and I program entirely in fortran. However,
> to compile PETSc, I need to use visual c++ in the past. Is it possible to
> use gcc or other c compilers to compile PETSc in cygwin?
Not - if you want to use PETSc from compaq fortran.
You can use gcc+g77 [or g95]
Satish
