need help with makefile
Satish Balay
balay at mcs.anl.gov
Fri Mar 2 11:16:12 CST 2007
>>>/usr/local/mpich-1.2.5.2/bin/mpif90 -c -I. -g __unsteady_ex.F -o unsteady_ex.o
"__unsteady_ex.F", line 965.2: 1515-019 (S) Syntax is incorrect.
The error is from mpif90 - not the preprocessor. Maybe its interpreting
the code as fixed form? Try adding '-qfree' to FFLAGS and see if it makes
a difference.
Satish
On Fri, 2 Mar 2007, P. Aaron Lott wrote:
> Thanks Satish,
> I checked the __unsteady_ex.F file. The preprocessor doesn't seem to like any
> of my fortran code. It starts complaining about the use of the use statements,
> and basically all the lines of code in this file.
> Any ideas?
> -Aaron
> Here are some of the statements the preprocessor complains about:
> use initialize
> use coordinates
> use maps
> use boundaries
> use elements
> use buildU
> use matrix_ops
> use output
> use d1ops
> use globaldata
> use dss
> use par_dss
> use forces
> use winds
> use stokes_solvers
> implicit none
> integer n,i,j
> real(kind=8) dt,gam
> integer nsteps
> type(coord) coords
> type(coord) proc_coords
> type(solution) GUXY,LUXY
> real(kind=8),allocatable, dimension(:):: force,wind
> integer nelements
> integer nely,nelx
> integer twod
> integer nglobaldofs
> integer irc,myrank,nprocs, ierr, status(MPI_STATUS_SIZE)
> call mpi_init(ierr)
> ! Get myrank
> call mpi_comm_rank(MPI_COMM_WORLD,myrank,ierr)
> call mpi_comm_size(MPI_COMM_WORLD,nprocs,ierr)
> call PetscInitialize( PETSC_NULL_CHARACTER, ierr )
> call MPI_Comm_rank( PETSC_COMM_WORLD, myrank, ierr )
> if (myrank .eq. 0) then
> print *, ?Hello World?
> endif
> call PetscFinalize(ierr)
> stop
> > > Thanks for this information. I think I setup things almost right, but
> > > something is causing preprocessor to complain. The errors it is giving are
> > > referring to lines of my main program file that doesn't exist.
> > The line numbers refer to the temoprary file created - __unsteady_ex.F
> > You can run the following command to preserve the temporary file - and
> > check it for the correct line number
> > make unsteady_ex SKIP_RM=yes
> > Preprocessing fortran code with C compiler can have some false
> > positives. For eg: if you have quotes in comments - then cpp can
> > misbehave.
> > > I would appreciate any recommendations about how to fix this problem. I've
> > > list some of the details of my setup below.
> > > Thanks,
> > > -Aaron
> > > e.g.
> > > macbeth% make unsteady_ex
> > > /usr/local/mpich-1.2.5.2/bin/mpicc
> > > -I/Users/palott/research/codes/petsc/petsc-2.3.2-p8
> > > c/petsc-2.3.2-p8/bmake/darwin-mpich-g
> > > -I/Users/palott/research/codes/petsc/petsc-2.3.2-p8/include
> > > -I/usr/local/mpich-1.2.
> > > 5.2/include -E -traditional-cpp __unsteady_ex.c | /usr/bin/grep -v
> > > *#' > __unsteady_ex.F
> > > unsteady_ex.o
> > > But there are only 207 lines in this file.....
> > > In my current makefile I have
> > > F90=mpif90
> > > F77=mpif77
> > These don't need to be specified as PETSc .F.o targets don't use them.. [and
> > you don't want to redefine whats already configured inside PETSc]
> > > F77FLAGS= -C -g -qdpc -qautodbl=dbl4 -qinitauto -Wl,-framework -Wl,vecLib
> > This variable is not used by PETSc target
> > PETSc should already use a blas implementation - so no need to specify
> > vecLib again.
> > > EXENAME = unsteady_ex
> > > CMD:=EXENAME
> > > SOBJS = mpi.o quicksort.o routines.o binsort.o coordinates.o comm_maps.o
> > > elements.o globaldata.o sem.o comp_inv.o d1ops.o maps.o pardss.o dss.o
> > > stiffness.o convection.o Mass.o pressure.o buildU.o wind.o forcing.o
> > > boundary_cond.o navier_stokes.o runge_kutta.o out.o gmres.o pcg.o
> > > stream.o
> > > uzawa.o print_matrices.o projection.o bdf.o stokes_solvers.o
> > > initialize_mpi.o unsteady_ex.o
> > > $(CMD) : $(SOBJS)
> > > -${FLINKER} $(FLAGS) -o $(EXENAME) $(SOBJS) $(PETSC_SYS_LIB)
> > No need to specify FLAGS here - as the default targets pick it up [in this
> > case
> > the flags get added to FLINKER
> > Satish
> > > mpi.o : ../Comm/mpi.f90 ;$(F90) $(FLAGS) -c
> > > ../Comm/mpi.f90
> > > gmres.o : ../Solvers/gmres.f90 ;$(F90) $(FLAGS) -c
> > > etc.... for all the object files except unsteady_ex.o
> > > unsteady_ex.F is my main program.
> > > In the example you gave, ex1f.F would be the main program, and at the top
> > > of
> > > the file it would have the statement:
> > > #include "include/finclude/petsc.h"
> > > So in my case, I've put that in the top of my unsteady_ex.F
> > > On Mar 1, 2007, at 5:56 PM, Satish Balay wrote:
> > > > The idea is to use a PETSc example makefile - and modify it
> > > > appropriately.
> > > > And with fortran codes - we require preprocessing [i.e source files
> > > > that call PETSc routines should be .F]
> > > > A minimal PETSc makefile is as follows:
> > > > CFLAGS =
> > > > FFLAGS =
> > > > CPPFLAGS =
> > > > FPPFLAGS =
> > > > CLEANFILES =
> > > > include ${PETSC_DIR}/bmake/common/base
> > > > ex1f: ex1f.o chkopts
> > > > -${FLINKER} -o ex1f ex1f.o ${PETSC_KSP_LIB}
> > > > ${RM} ex1f.o
> > > > So you'll just make the change [with the variables CMD and SOBJS
> > > > properly
> > > > defined]
> > > > ex1f -> $(CMD)
> > > > ex1f.o -> $(SOBJS)
> > > > Note: Necessary FFLAGS should already be PETSc config files. Some
> > > > additional flags can be specified with FFLAGS variable
> > > > Satish
> > > > On Thu, 1 Mar 2007, P. Aaron Lott wrote:
> > > > > Hi,
> > > > > I have a fortran90 code and I would like to use petsc's
> > > > > preconditioners
> > > > > inside of it. I'm having trouble setting up a makefile that will allow
> > > > > me
> > > > > include a petsc. It seems the problem is from the use of the
> > > > > c-preprocessor.
> > > > > My old makefile looked something like this:
> > > > > $(CMD) : $(SOBJS)
> > > > > $(F90) $(FLAGS) -o $(EXENAME) $(SOBJS)
> > > > > where SOBJ is a list of all of my object files.
> > > > > I was hoping to be able to make a petsc object file and include it in
> > > > > this
> > > > > list. Is this possible? Is there a tutorial on how to get petsc setup
> > > > > inside
> > > > > of your existing code?
> > > > > Thanks,
> > > > > -Aaron
> > > > > P. Aaron Lott
> > > > > Ph.D. Candidate
> > > > > 4239 Computer and Space Sciences Building
> > > > > University of Maryland
> > > > > College Park, MD 20742-4015
> > > > > palott at ipst.umd.edu
> > > > > http://www.lcv.umd.edu/~palott
> > > > > Office: 301.405.4894
> > > > > Fax: 301.314.0827
> > > P. Aaron Lott
> > > Ph.D. Candidate
> > > Fax: 301.314.0827
> P. Aaron Lott
> Ph.D. Candidate
> Fax: 301.314.0827
