KSP/PC choice
Stephan Kramer stephan.kramer at imperial.ac.uk
Fri Jul 27 05:58:14 CDT 2007
Hi Tim,
As Guy said MUMPS is a direct solver, i.e. it constructs the inverse of
the matrix (in some sense) and applies that to the rhs. This means first
of all you need quite a lot of memory, as  you need to store a dense
matrix, but also that there is no iterative process. You do not/should
not supply an initial guess. ksp_type should really be preonly, anything
else doesn't make sense. As there are no iterations, it also doesn't
return a number of iterations and there is also no convergence to
monitor,
Hope this helps
Cheers
Stephan
On Fri, 2007-07-27 at 09:21 +0200, Tim Kröger wrote:
> Dear Matt
> On Wed, 25 Jul 2007, Matthew Knepley wrote:
> >> -ksp_type preonly
> >> -pc_type lu
> >> -mat_type aijmumps
> >> -ksp_monitor
> > It appears that you never call MatSetFromOptions() on the matrix you
> > create, which would prevent the option from changing the type.
> Thank you very much for your help.  Now, the MUMPS solver is working
> for me, and it really seems to solve the problem that I was working on
> for nearly a year now!
> However, I have one more question: I usually call
> KSPGetIterationNumber() after the solve, and if it tells me that 0 KSP
> iterations have been used, I assume that the initial guess was already
> accurate enough.  In this case, I don't have to solve the system in
> the next time steps anymore until some change of the setting takes
> place (which happens from time to time in my application).  This saves
> a lot of computational time.  However, with the MUMPS solver,
> KSPGetIterationNumber() never supplies 0.  Is there any possibility to
> find out whether the initial guess was accurate enough?
> (It might be noteworthy that I use "-ksptype richardson" instead of
> "-ksptype preonly" since in the latter case I get an error message due
> to my non-zero initial guess.)
> Also, I would like to know whether there is any possibility to monitor
> the convergence of the MUMPS solver (analogously to -kspmonitor).
> Best Regards,
> Tim
