Scattering context options
Graham Kells
gkells at thphys.nuim.ie
Fri Jul 27 06:19:33 CDT 2007
Hi ,
I'm scattering from a global vector (used as a kind of look up table)
to a bunch of local vectors and then using the values in the local
vectors as indices to populate a global matrix.
The basic population routine goes something like this
do myrow=Istart,Iend-1
! Returns column indices of full matrix for rowindex list(myrow+1)
call getrow(list(myrow+1),rowCOO,colCOO,valCOO)
call ISCreateGeneral(PETSC_COMM_WORLD,n,(colCOO-1),from,ierr)
call ISCreateGeneral(PETSC_COMM_SELF,n,idx_to-1,to,ierr)
call VecScatterCreate(vlist,from,outvec,to,scatter,ierr)
call
VecScatterBegin(scatter,vlist,outvec,INSERT_VALUES,SCATTER_FORWARD,ierr)
call
VecScatterEnd(scatter,vlist,outvec,INSERT_VALUES,SCATTER_FORWARD,ierr)
call VecScatterDestroy(scatter,ierr)
call ISDestroy(from,ierr)
call ISDestroy(to,ierr)
call VecGetValues(outvec,n,idx_to-1,idx_real,ierr)
idx_from=int(idx_real)
call MatSetValues(A,1,myrow,n,idx_from-1,valCOO,INSERT_VALUES,ierr)
end do
While this works, it is prohibitively slow. Any ideas on why this is?
Of course if you can suggest a better way of doing this that would be great.
Supposing you can't and I want to experiment with different MPI
communication modes within the scatter context. How do specify the
MPI_Ssend option, for example?
Thanks in advance,
Graham
