Poisson Eqn in a concentric cube
#DOMINIC DENVER JOHN CHANDAR# DOMI0002 at ntu.edu.sg
Tue Jul 24 04:19:12 CDT 2007
Thanks Matt,
Yeah, I had this in mind... Since its an academic exercise, I guess its
not much of a problem.
Dominic
-----Original Message-----
[mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Tuesday, July 24, 2007 5:05 PM
To: petsc-users at mcs.anl.gov
Subject: Re: Poisson Eqn in a concentric cube
Currently, the DA does not directly support cutout grids, as you have
shown above. However, you could just substitute the identity for all
points in the cutout, and only suffer from an excessive preallocation.
Does this make sense?
     Matt
On 7/23/07, #DOMINIC DENVER JOHN CHANDAR# <DOMI0002 at ntu.edu.sg> wrote:
> Hi,
>      I would like to solve the Poisson equation (3D) in a concentric
> type of cube as in the attached figure using PETSc. The solution
> domain would be the shaded region only and it extends inside the cube.
> I would like to have suggestions on ways to form and assemble the
> matrix associated with the discretization. Also, is it a good practise
> to discretize the entire domain and blank the grid points which are
within the cube not in the domain ?
> Regards,
> Dominic
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
