Configuration crash on Windows : ALWAYS
Mon Jul 23 10:20:54 CDT 2007
> Traceback (most recent call last):   File "C:\Python\lib\threading.py", line
PETSc requires cygwin python as per installation instruction.
[looks like you are using non-cygwin python - which won't work]
Satish
On Mon, 23 Jul 2007, Matthew Knepley wrote:
> You did not send configure.log. However, try running with --useThreads=0.
>  Matt
> On 7/23/07, Sumit Vaidya <sumit_vaidya at persistent.co.in> wrote:
> > When I build PETSc 2.3.3-p3 on Windows I always get the following error.
> > Exception in thread Shell Command:
> > 460, in __bootstrap
> >     self.run()
> >   File "C\Python\lib\threading.py", line 440, in run
> >     self.__target(*self.__args, **self.__kwargs)
> > And I see "CONFIGURATION CRASH".
> > This is always.
> > Reading about this on the mailing lists, I came to know that it is related
> > to some test case. Is there any way to stop this testing of library?
> > How to resolve this error?
> > Waiting for your reply,
> > Sumit
> > DISCLAIMER ========== This e-mail may contain privileged and confidential
> > information which is the property of Persistent Systems Pvt. Ltd. It is
> > intended only for the use of the individual or entity to which it is
> > addressed. If you are not the intended recipient, you are not authorized to
> > read, retain, copy, print, distribute or use this message. If you have
> > received this communication in error, please notify the sender and delete
> > all copies of this message. Persistent Systems Pvt. Ltd. does not accept any
> > liability for virus infected mails.
