KSP/PC choice
Tim Kröger tim at cevis.uni-bremen.de
Mon Jul 23 09:58:17 CDT 2007
Dear Lissandro,
On Mon, 23 Jul 2007, Lisandro Dalcin wrote:
> On 7/23/07, Tim Kröger <tim at cevis.uni-bremen.de> wrote:
>> the more KSP and PC methods are available, the more difficult it is to
>> choose a suitable one.
>> I want to compute Navier-Stokes (using Finite Elements) for
>> medium-sized Reynolds numbers (still laminar, though).  I am currently
>> using
> Are you solving incompresible flow?
Yes.
> Tansient or steady state?
Transient.
> Are you using a monolithic formulation; or a fractional-step like
> formulation?
Monolithic.  (I am not quite sure about this word but I assume it
means that I don't try to decouple the two equations.)
> What kind of stabilization for advection and pressure are you using?
Streamline diffusion (for advection).  I am not aware of the
requirement to stabilize the pressure as well.
> I ask this because in my experience incompressible flows with
> monolithic formulations are usually hard to solve, and a good choice
> of stabilization method not only leads to better final solution, but
> also lead to linear systems with better conditioning.
Would you recommend to use a fractional step method?  Would you
recommend a different stabilization method?  If you have any
suggestion, please let me know.
Best Regards,
Tim
Dr. Tim Kroeger                            Phone +49-421-218-7710
tim at mevis.de, tim at cevis.uni-bremen.de      Fax   +49-421-218-4236
MeVis Research GmbH, Universitaetsallee 29, D-28359 Bremen, Germany
Amtsgericht Bremen HRB 16222
Geschaeftsfuehrer: Prof. Dr. H.-O. Peitgen
