PETSc compiler
Sumit Vaidya
sumit_vaidya at persistent.co.in
Fri Jul 20 00:16:25 CDT 2007
Well I am planning to use icl and ifort compilers on windows.
Is it possible to build it without Cygwin?
Sumit
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov]
On Behalf Of Satish Balay
Sent: Thursday, July 19, 2007 8:35 PM
To: petsc-users at mcs.anl.gov
Subject: RE: PETSc compiler
On Thu, 19 Jul 2007, Sumit Vaidya wrote:
> I am sorry.
> I want to build it on windows. I forgot to mention that. On windows I will
> not be having "configure.py" script.
You'll have to follow the installation instructions from:
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
you'll need to run config/configure.py [from cygwin] on windows -
as per the installation instructions.
Sepecifically - check the instruction in 'Additional Microsoft Windows
Notes:' section.
BTW: what compilers [c, fortran] do you plan to use on windows?
Satish
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
