PETSc compiler
Sumit Vaidya
sumit_vaidya at persistent.co.in
Thu Jul 19 09:38:50 CDT 2007
Where is the option to change the compiler?
I saw $PCC in the bmake/common/variables file. Now I want to change the
compiler.
Where should I specify it?
Sumit
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070719/2163a840/attachment.htm>
