Petsc on Blue Gene
Lisandro Dalcin dalcinl at gmail.com
Wed Jul 11 20:07:07 CDT 2007
On 7/11/07, Brian Biskeborn <bbiskebo at us.ibm.com> wrote:
> Lisandro:
> The compiler guarantees proper alignment of stack-allocated and
> statically-allocated data. Also, I think the Blue Gene implementation of
> malloc always returns 16-byte aligned addresses.
In my 32bits linux FC6 box, I compile the following
#include <stdio.h>
#include <malloc.h>
typedef unsigned us;
#define PRINTP(p) \
  printf("p=%p p mod 4=%u p mod 8=%u \n",\
	 p, (us)(((us)p)%4), (us)(((us)p)%8))
int main(int argc, char* argv[]) {
  int iv1,iv2,iv3;
  int *ip1 = &iv1;
  int *ip2 = &iv2;
  int *ip3 = &iv3;
  printf("stacked\n");
  PRINTP(ip1); PRINTP(ip2); PRINTP(ip3);
  ip1 = (int*) malloc(sizeof(int));
  ip2 = (int*) malloc(sizeof(int));
  ip3 = (int*) malloc(sizeof(int));
  printf("malloced\n");
  return 0;
and next run
$ a.out
stacked
p=0xbff66184 p mod 4=0 p mod 8=4
p=0xbff66180 p mod 4=0 p mod 8=0
p=0xbff6617c p mod 4=0 p mod 8=4
malloced
p=0x9caf008 p mod 4=0 p mod 8=0
p=0x9caf018 p mod 4=0 p mod 8=0
p=0x9caf028 p mod 4=0 p mod 8=0
So malloced mem is 8 bytes aligned (is this the definition for
aligned?), but addresses to local, stacked integer variables are 4
bytes.
So this makes me think that perhaps PETSc is treating all adresses as
malloced and in some place this can cause problems (you said you were
using a custom PETSC_MEMALIGN)...
As I said, my knowledge of this is 0 (zero), this is just an idea, and
forget me if all this does not make any sense
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
