Reading a Sparse matrix in CRS format from a function to be used in parallel linear solvers
    Hong Zhang
    hzhang at mcs.anl.gov
    Wed Jan 31 09:57:07 CST 2007
Dominic,
You may use MatCreateMPIIJWithArrays() to achieve this.
Hong
On Wed, 31 Jan 2007, Matthew Knepley wrote:
> On 1/31/07, #DOMINIC DENVER JOHN CHANDAR# <DOMI0002 at ntu.edu.sg> wrote:
> >  Hi,
> >        I have a function which creates a sparse matrix following a certain
> > eqn and returns a pointer to the row, column index and the value of a sparse
> > matrix (CRS- form).
> > i   j   val
> > 1  1  1.0
> > 2  2  1.0
> > 2  3  -1.5..
> > so on...
> >  The matrix *may not **have a definite pattern* like the one we see for
> > tridiagonal or pentadiagonal matrices or the test cases (linear solvers)
> > cited in the petsc documentation. Now, i would like to use the linear
> > solvers in petsc to solve the system of equations. I do not want to write
> > that sparse matrix into a file and read it into petsc since it may be
> > huge.I would like to call that function from petsc and would return the
> > pointer to i j and val and insert values of this sparse matrix using
> > MatSetValues in parallel. How can I achieve this ?
> We do not have CRS format as it is not a very space efficient format. Most
> of our formats are row-oriented. I suggest
> looking at the example for MatSetValues() and trying to rework the
> discretization function to directly call this. Most
> discretizations naturally generate row-by-row values or even blocks like
> FEM. Even totally nustructured stuff from
> economics is row-by-row.
>   Thanks,
>     Matt
> Cheers,
> > Dominic
> One trouble is that despite this system, anyone who reads journals widely
> and critically is forced to realize that there are scarcely any bars to
> eventual
> publication. There seems to be no study too fragmented, no hypothesis too
> trivial, no literature citation too biased or too egotistical, no design too
> warped, no methodology too bungled, no presentation of results too
> inaccurate, too obscure, and too contradictory, no analysis too
> self-serving,
> no argument too circular, no conclusions too trifling or too unjustified,
> and
> no grammar and syntax too offensive for a paper to end up in print. --
> Drummond Rennie
