Reading a Sparse matrix in CRS format from a function to be used in parallel linear solvers
#DOMINIC DENVER JOHN CHANDAR#
DOMI0002 at ntu.edu.sg
Wed Jan 31 00:43:45 CST 2007
I have a function which creates a sparse matrix following a
certain eqn and returns a pointer to the row, column index and the value
of a sparse matrix (CRS- form).
i j val
1 1 1.0
2 2 1.0
2 3 -1.5..
so on...
The matrix may not have a definite pattern like the one we see for
tridiagonal or pentadiagonal matrices or the test cases (linear solvers)
cited in the petsc documentation. Now, i would like to use the linear
solvers in petsc to solve the system of equations. I do not want to
write that sparse matrix into a file and read it into petsc since it may
be huge.I would like to call that function from petsc and would return
the pointer to i j and val and insert values of this sparse matrix using
MatSetValues in parallel. How can I achieve this ?
Cheers,
Dominic
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070131/cd51ee2e/attachment.htm>
