PETSc
Aron Ahmadia
aja2111 at columbia.edu
Sat Jan 27 18:43:45 CST 2007
Sorry, that should have been subroutine, not application.
~A
On 1/27/07, Aron Ahmadia <aja2111 at columbia.edu> wrote:
> Brian,
> Work vectors should never be created/deleted every time an application
> is run, they should be generated at the beginning and then accessed.
> In this case calling get/restore should be fine.
> ~A
> > > Sounds like a documentation bug to me, are you referring to this?
> > http://www-unix.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-current/docs/manualpages/DA/DARestoreGlobalVector.html#DARestoreGlobalVector
> > > Perhaps I'm misunderstanding how Get/Restore are being used. I'll let
> > > one of the developers chime in on this when they've got a moment.
> > This is a cut&paste error from GetLocalVector().
> > Matt
> > > ~A
> > > On 1/27/07, Brian Grierson < bag2107 at columbia.edu> wrote:
> > > > Another quick question. PETSc online help says
> > DAGetGlobal/DARestoreGlobal
> > > > is a Seq vector operation, while
> > > > DACreateGlobal/VecDesroy is parallel.
> > > > I don't understand how you could create a global vector in a Seq manner
> > on a
> > > > DA???
> > > > Brian A. Grierson
> > > > Department of Applied Physics
> > > > Columbia University
> > > > Mobile: 646.259.1038
> > > > Work: 212-854-4839
> > > > bgrierson21 at gmail.com
> > http://www.columbia.edu/~bag2107/http://www.apam.columbia.edu/ctx/ctx.html
> > > > On Jan 27, 2007, at 6:41 PM, Aron Ahmadia wrote:
> > > > Hi Brian,
> > > > I took a quick peek at the source for DAGetGlobalVector in the current
> > > > release:
> > > > for (i=0; i<DA_MAX_WORK_VECTORS; i++) {
> > > > if (da->globalin[i]) {
> > > > *g = da->globalin[i];
> > > > da->globalin[i] = PETSC_NULL;
> > > > goto alldone;
> > > > ierr = DACreateGlobalVector(da,g);CHKERRQ(ierr);
> > > > alldone:
> > > > if (!da->globalout[i]) {
> > > > da->globalout[i] = *g;
> > > > break;
> > > > The two appear to be very similar, with this exception. Get/Restore
> > > > work with one copy of the DA's global vector, but will make a copy if
> > > > one has already been checked out or none exist.
> > > > DACreateGlobalVector will always make a copy of the global vector,
> > > > regardless of the circumstances. I think you're better off using Get
> > > > and Restore (less data copying) unless you'd like to work with
> > > > multiple copies for some reason.
> > > > ~A
> > > > Could you please tell me the difference between
> > > > DACreateGlobalVector / VecDestroy
> > > > and
> > > > DAGetGlobalVector / DARestoreGlobalVector
> > > > Brian A. Grierson
> > > > Columbia University
> > > > Work: 212-854-4839
> > One trouble is that despite this system, anyone who reads journals widely
> > and critically is forced to realize that there are scarcely any bars to
> > eventual
> > publication. There seems to be no study too fragmented, no hypothesis too
> > trivial, no literature citation too biased or too egotistical, no design too
> > warped, no methodology too bungled, no presentation of results too
> > inaccurate, too obscure, and too contradictory, no analysis too
> > self-serving,
> > no argument too circular, no conclusions too trifling or too unjustified,
> > and
> > no grammar and syntax too offensive for a paper to end up in print. --
> > Drummond Rennie
