Lapack/blas and Gotoblas
Ben Tay zonexo at gmail.com
Fri Jan 26 21:56:11 CST 2007
The result I get for lapack is
/usr/lib/liblapack.a  /usr/lib/liblapack.so  /usr/lib/liblapack.so.3
/usr/lib/liblapack.so.3.0  /usr/lib/liblapack.so.3.0.3
but for blas, there's no match. However, my school's tutorial said lapack
and blas can be used with the option -llapack -lblas.
Is there some other directory where they are usually install?
I'm wondering if I can use lapack + gotoblas together? I tried to specify
the libraries but ./configure failed.
Thank you.
On 1/27/07, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sat, 27 Jan 2007, Ben Tay wrote:
> > My school's server has lapack and blas installed. However, I can't
> > get it to be automatically detected by using ./configure. what is
> > the filename that I should used?
> what do you have for:
> ls /usr/lib/libblas* /usr/lib/liblapack*
> > Btw, can I use GotoBlas? I tried to specify libgoto.a or
> > libgoto_northwoodp- r1.10.so and I managed to compile. However,
> > during testing, the error msg are
> yeah - you can use gotoblas - but you'll still need lapack.
> > /nas/lsftmp/g0306332/petsc-2.3.2-p8/lib/linux-nompi-goto/libpetscksp.so:
> > undefined reference to `pthread_join'
> Lools like goto requires -lpthread
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070127/1a0b2bce/attachment.htm>
