MPI forum similar to PETSc for MPI problems?
Ben Tay zonexo at gmail.com
Fri Jan 19 19:56:38 CST 2007
I've encountered some MPI programming problems. Does anyone know of a
mailing list sort of discussion forum similar to this PETSc one which deals
with MPI?
Btw, my question is as follow, it will be great if someone can help too ;-)
It's in fortran but I guess it should be similar in C. Put it simply, how do
I broadcast part of a derived type variable to other processors ie
type particle
real x,y,z
integer number
end type particle
type(particle) part(10,10)
So I want to broadcast part(:,:)%x to other processors. How can I do that? I
tried to use:
call MPI_BCAST(part(i,j)%x, 1, MPI_Real,1, MPI_COMM_WORLD, ierr) but it
can't work.
Thank you very much
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070120/0f5a88a4/attachment.htm>
