Vector containing one number
Barry Smith
bsmith at mcs.anl.gov
Fri Jan 19 07:53:52 CST 2007
This routine does make sends and receives of length zero;
this is legal in MPI but possibly Open-MPI has bugs dealing with
this.
Barry
On Fri, 19 Jan 2007, Berend van Wachem wrote:
> Hi,
> valgrind shows something related to open-mpi, see below. I'll try mpich
> to see if the problem goes away.
> Thanks,
> Berend.
> ==3683== Syscall param writev(vector[...]) points to uninitialised
> byte(s)
> ==3683== at 0x543A607: writev (in /lib64/tls/libc-2.3.6.so)
> ==3683== by 0x5BE0AEA: mca_oob_tcp_msg_send_handler
> (in /usr/local/lib/openmp
> i/mca_oob_tcp.so)
> ==3683== by 0x5BE1827: mca_oob_tcp_peer_send
> (in /usr/local/lib/openmpi/mca_o
> ob_tcp.so)
> ==3683== by 0x5BE5B93: mca_oob_tcp_send_nb
> (in /usr/local/lib/openmpi/mca_oob
> _tcp.so)
> ==3683== by 0x4B47DBD: _orte_iof_base_frag_ack
> (in /usr/local/lib/liborte.so.
> 0.0.0)
> ==3683== by 0x4B47639: orte_iof_base_endpoint_forward
> rte.so.0.0.0)
> ==3683== by 0x6D45538: orte_iof_svc_proxy_recv
> _iof_svc.so)
> ==3683== by 0x5BE137A: mca_oob_tcp_msg_recv_complete
> pi/mca_oob_tcp.so)
> ==3683== by 0x5BE2D18: mca_oob_tcp_peer_recv_handler
> pi/mca_oob_tcp.so)
> ==3683== by 0x4C7E466: opal_event_loop
> (in /usr/local/lib/libopal.so.0.0.0)
> ==3683== by 0x4C78A55: opal_progress
> ==3683== by 0x4030AF: opal_condition_wait (condition.h:81)
> ==3683== Address 0x41CF348 is not stack'd, malloc'd or (recently)
> free'd
