Serial Petsc with SuperKU_dist
Barry Smith
bsmith at mcs.anl.gov
Fri Jan 19 07:48:10 CST 2007
Not, Superlu DIST requires a real MPI implementation (
but, of course, can be be run on just one process if you want). But
for sequential solves you can just use Superlu.
Barry
On Fri, 19 Jan 2007, #DOMINIC DENVER JOHN CHANDAR# wrote:
> Hi
> Is it possible to build the serial version of PETSc with
> SuperLU_DIST_2.0 ? or should i use the parallel version only ?
> Thanks,
> Dominic
