mpi not working
li pan
li76pan at yahoo.com
Mon Jan 15 10:31:59 CST 2007
I did try to download and install petsc2.3.2, but end
up with error: mpich can not be download & installed,
please install mpich for windows manually.
In the homepage of mpich2, I didn't choose the version
for windows but the source code version. And compiled
it by myself. Then, I gave the --with-mpi-dir="install
dir". Petsc was configured, and now it's doing "make".
One interesting thing is, I installed petsc in linux
before. The mpi libraries were very large
(libmpich.a==60 mb). But this time in cygwin it was
only several mbs.
best
pan
--- Ben Tay <zonexo at gmail.com> wrote:
> hi,
> i install PETSc using the following command:
> ./config/configure.py --with-vendor-compilers=intel
> --with-gnu-compilers=0
--with-blas-lapack-dir=/lsftmp/g0306332/inter/mkl/lib/32
> --with-mpi-dir=/opt/mpich/intel/ --with-x=0
> --with-shared
> then i got:
> Compilers:
> C Compiler: /opt/mpich/intel/bin/mpicc
> -fPIC -g
> Fortran Compiler: /opt/mpich/intel/bin/mpif90
> -I. -fPIC -g -w90 -w
> Linkers:
> Shared linker: /opt/mpich/intel/bin/mpicc
> -shared -fPIC -g
> Dynamic linker: /opt/mpich/intel/bin/mpicc
> -shared -fPIC -g
> PETSc:
> PETSC_ARCH: linux-mpif90
> PETSC_DIR: /nas/lsftmp/g0306332/petsc-2.3.2-p8
> ** Now build and test the libraries with "make all
> test"
> Clanguage: C
> Scalar type:real
> MPI:
> Includes: ['/opt/mpich/intel/include']
> PETSc shared libraries: enabled
> PETSc dynamic libraries: disabled
> BLAS/LAPACK:
> -Wl,-rpath,/lsftmp/g0306332/inter/mkl/lib/32
> -L/lsftmp/g0306332/inter/mkl/lib/32 -lmkl_lapack
> -lmkl_ia32 -lguide
> i ran "make all test" and everything seems fine
> /opt/mpich/intel/bin/mpicc -c -fPIC -g
-I/nas/lsftmp/g0306332/petsc-2.3.2-p8-I/nas/lsftmp/g0306332/petsc-
> 2.3.2-p8/bmake/linux-mpif90
> -I/nas/lsftmp/g0306332/petsc-2.3.2-p8/include
> -I/opt/mpich/intel/include
> -D__SDIR__="src/snes/examples/tutorials/" ex19.c
> /opt/mpich/intel/bin/mpicc -fPIC -g -o ex19
> ex19.o-Wl,-rpath,/nas/lsftmp/g0306332/petsc-
> 2.3.2-p8/lib/linux-mpif90
-L/nas/lsftmp/g0306332/petsc-2.3.2-p8/lib/linux-mpif90
> -lpetscsnes -lpetscksp -lpetscdm -lpetscmat
> -lpetscvec -lpetsc
> -lmkl_ia32 -lguide
> -lPEPCF90 -Wl,-rpath,/opt/intel/compiler70/ia32/lib
> -Wl,-rpath,/opt/mpich/intel/lib
> -L/opt/mpich/intel/lib -Wl,-rpath,-rpath
> -Wl,-rpath,-ldl -L-ldl -lmpich
> -L/opt/intel/compiler70/ia32/lib
> -Wl,-rpath,/usr/lib -Wl,-rpath,/usr/lib -L/usr/lib
> -limf -lirc -lcprts -lcxa
> -lunwind -ldl -lmpichf90 -lPEPCF90
> -L/opt/intel/compiler70/ia32/lib -Wl,-rpath,/usr/lib
> -L/usr/lib -lintrins
> -lIEPCF90 -lF90 -lm -Wl,-rpath,\ -Wl,-rpath,\ -L\
> -ldl -lmpich
> -Wl,-rpath,/usr/lib -L/usr/lib -limf -lirc -lcprts
> -lcxa -lunwind -ldl
> /bin/rm -f ex19.o
> C/C++ example src/snes/examples/tutorials/ex19 run
> successfully with 1 MPI
> process
> successfully with 2 MPI
> processes
> Fortran example src/snes/examples/tutorials/ex5f run
> process
> Completed test examples
> I then tried to run my own parallel code. It's a
> simple code which prints
> the rank of each processor.
> If I compile the code using just mpif90 test.F(using
> just mpif.h)
> I get 0,1,2,3 (4 processors).
> however, if i change the code to use petsc.h etc
> ie.
> program ns2d_c
> implicit none
> #include "include/finclude/petsc.h"
> #include "include/finclude/petscvec.h"
> #include "include/finclude/petscmat.h"
> #include "include/finclude/petscksp.h"
> #include "include/finclude/petscpc.h"
> #include "include/finclude/petscmat.h90"
> integer,parameter :: size_x=8,size_y=4
> integer ::
> ierr,Istart_p,Iend_p,Ntot,Istart_m,Iend_m,k
> PetscMPIInt nprocs,rank
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> call
> MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
> call
> MPI_Comm_size(PETSC_COMM_WORLD,nprocs,ierr)
> end program ns2d_c
> i then rename the filename to ex2f.F and use "make
> ex2f"
> the result I get is something like 0,0,0,0.
> Why is this so?
> Thank you.
____________________________________________________________________________________
Never Miss an Email
Stay connected with Yahoo! Mail on your mobile. Get started!
http://mobile.yahoo.com/services?promote=mail
