Some questions about the parallel implementation of PETSc
Fri Jan 12 21:02:16 CST 2007
  Ben,
  Sounds like you are using a logically rectangular grid in two dimensions?
(or 3). If so I highly recommend using the DMMG infrastructure in PETSc it
handles all the decomposition of the domain into subrectangles, preallocates the
matrix, handles ghost point updates and even lets you using multigrid. Check
src/ksp/ksp/examples/tutorials/ex29.c and ex22.c
  Good luck,
   Barry
On Sat, 13 Jan 2007, Ben Tay wrote:
> Hi,
> I've the sequential version of PETSc working and I have some questions about
> the parallel implementation.
> My code is to solve the NS eqn. Mainly it has to solve 2 linear eqns -
> momentum & poisson. The poisson eqn solving takes the most % of time so it
> going to be solved in parallel. Most likely the momentum eqn 'll be as well.
> The other parts of the code may be parallelized later using MPI.
> The parallel part is coded as follows:
> call MatCreate(PETSC_COMM_WORLD,A,ierr)
> call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,m*n,m*n,ierr)
> call MatSetFromOptions(A,ierr)
> call MatGetOwnershipRange(A,Istart,Iend,ierr)
> call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,b,ierr)
> call VecSetFromOptions(b,ierr)
> call VecDuplicate(b,x,ierr)
> ... insert matrix in parallel making use of Istart,Iend.
> ... assembly
> ... solve
> Since I've used PETSC_DECIDE, PETSc will determine the local dimension of A
> and b and x automatically.
> Is the no. of rows of A and b and x (Iend-Istart+1) locally?
> After the eqn is solved, I need to obtain the answer x
> I've used:
> call VecGetArray(x,ppv,i_vec,ierr)
> do j=1,size_y
>     do i=1,size_x
>        k=(j-1)*size_x+i
>        p(i,j)=ppv(k+i_vec)
>     end do
> end do
> call VecRestoreArray(x,ppv,i_vec,ierr)
> I'm trying to get the address of the 1st value of x and map the values onto
> a rectangular grid to update p. Is this correct?
> Or am I only able to get the local value, as in the local value of x. Do I
> need to use some MPI routines if I need to update the p values on the whole
> global grid?
> thanks alot!
