Using parMetis in petsc for ordering
Dimitri Lecas
dimitri.lecas at free.fr
Thu Jan 11 15:00:11 CST 2007
Barry Smith a écrit :
> On Thu, 11 Jan 2007, Dimitri Lecas wrote:
>> Barry Smith a �crit :
>>> Dimitri,
>>> No, I think this is not the correct way to look at things. Load
>>> balancing the original matrix is not neccessarily a good thing for
>>> doing an LU factorization (in fact it is likely just to make the LU
>>> factorization have much more fill and require much more floating
>>> operations).
>>> Packages like SuperLU_dist and Mumps have their own internal ordering
>>> routines that are specifically for getting a good ordering for doing
>>> the parallel LU factorization, you should just have these solvers
>>> use them (which they do automatically).
>>> Barry
>> I'am no longer talking about doing LU factorization. But use iterative method
>> for solving a linear system, like bicg. Like in the ex10. In this example i
>> don't understand why using MatPartitioning.
> Please rephrase the question. Are you asking why one should do the partition
> or why one should not? Are you asking in the case where the matrix is read from
> disk or generated in a parallel program?
I try to understand the interest to call MatPartitioning before solving
the linear system with the same matrix. (Like
ksp/examples/tutorials/ex10.c).
Dimitri Lecas
