PETSc and gfortran
Paul T. Bauman
pbauman at ices.utexas.edu
Wed Jan 10 18:46:00 CST 2007
I'm such an idiot... PETSc was compiled with an older version of
gfortran than what I compiled my code with. gdb illuminated this for me
(it was looking for the old gfortran libraries that weren't there).
Sorry to waste your time. Everything is working now. Thanks again for
your prompt help.
Paul
Satish Balay wrote:
> BUS error is a bit suspicious. What can you send the output from all
> of the following commands..
> cd src/ksp/ksp/examples/tutorials
> make ex2f
> ./ex2f
> gdb ex2f
> (gdb) run
> Satish
> On Wed, 10 Jan 2007, Paul T. Bauman wrote:
>> Yes, example ex5f broke in the exact same way. Note the preceding c/c++
>> examples worked perfectly. How would you suggest I proceed? Thanks,
>> Paul
>> Satish Balay wrote:
>>> Can you reproduce this with a PETSc example?
>>> make test
>>> Satish
>>>> Hello,
>>>> Has anyone had any experience using PETSc and gfortran together? My code
>>>> compiles, but when I run it, it crashes with the following error (mac
>>>> Tiger
>>>> 10.4.8, power pc, latest build of gfortran, MPICH2, petsc 2.3.2):
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly illegal
>>>> memory access
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
>>>> ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
>>>> find
>>>> memory corruption errors
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>>>> [0]PETSC ERROR: is given.
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Signal received!
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 8, Tue Jan 2 14:33:59
>>>> PST
>>>> 2007 HG revision: ebeddcedcc065e32fc252af32cf1d01ed4fc7a80
>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: EXEC/shrink_tao on a Apple_Pow named
>>>> dhcp-67-30.ices.utexas.edu by pbauman Wed Jan 10 17:20:03 2007
>>>> [0]PETSC ERROR: Libraries linked from
>>>> /Users/pbauman/LIBRARIES/PETSC/petsc-2.3.2-p8/lib/Apple_PowerPC_Tiger_Debug
>>>> [0]PETSC ERROR: Configure run at Tue Jan 9 15:42:42 2007
>>>> [0]PETSC ERROR: Configure options --with-shared=0 --with-clanguage=C++
>>>> --with-mpi-dir=/Users/pbauman/LIBRARIES/MPICH/mpich2-1.0.5_Apple_PowerPC_Tiger_gcc_gfortran
>>>> --with-blas-lapack-dir=/Users/pbauman/LIBRARIES/PETSC/petsc-2.3.2-p8/externalpackages/fblaslapack/Apple_PowerPC_Tiger_Debug/
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: User provided function() line 0 in unknown directory
>>>> unknown
>>>> file
>>>> [cli_0]: aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>> rank 0 in job 2 dhcp-67-30.ices.utexas.edu_50482 caused collective
>>>> abort of
>>>> all ranks
>>>> exit status of rank 0: return code 59
>>>> make: *** [run_shrink_tao_tr] Error 59
>>>> This happens at the very beginning of the code (I put a write statement in
>>>> at
>>>> the first line of the program and nothing came out). This code runs
>>>> successfully on linux with intel compilers. I'm sure the problem is
>>>> somehow
>>>> with gfortran/my build, I'm just not sure where to begin with this kind of
>>>> problem, so I thought I'd see if anyone had a similar experience.
>>>> Thanks,
>>>> Paul
