MatView() and Multiple Processes
Tim Stitt
timothy.stitt at ichec.ie
Sun Dec 9 11:37:07 CST 2007
Hi all,
I was just wondering if someone can tell me how to configure my
dual-core laptop to allow graphical X11 output of my PETSc matrices.
MatView() works fine on my parallel code with 1 process but I get the
following errors on each process when I use more than one:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Error in external library!
[0]PETSC ERROR: Unable to open display on localhost.localdomain:0.0
. Make sure your COMPUTE NODES are authorized to connect
to this X server and either your DISPLAY variable
is set or you use the -display name option
Thanks in advance as always,
Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax)
