PetscPrintf/ifort 9.1
Paul T. Bauman pbauman at ices.utexas.edu
Tue Aug 28 22:45:06 CDT 2007
Awesome. Thanks so much.
Barry Smith wrote:
>   Paul,
>    I have pushed a fix to petsc-dev that resolves this problem. If you are
> not using petsc-dev you can simply replace the file
> src/sys/fileio/ftn-custom/zmprintf.c with the attached file then run
> make lib shared
> in that directory then relink your program.
>    Barry
> On Tue, 28 Aug 2007, Paul T. Bauman wrote:
>> Hello,
>> Kind of a non-numerical question - sorry.  I'm using PetscPrintf from Fortran
>> using the following calling sequence (for example):
>>     call PetscPrintf(PETSC_COMM_WORLD,
>> "=============================================== \n", ierr)
>>     call PetscPrintf(PETSC_COMM_WORLD, "               Beginning of Program
>> \n", ierr)
>> On my mac laptop (PowerPC) with PETSc 2.3.2-p7 compiled with gcc 4.0.1 and
>> g95, this prints as expected:
>> On a linux workstation (AMD Opteron) with PETSc 2.3.2-p7 compiled with icc,
>> icxx, ifort 9.1, the "\n" is treated as a character and not treated as "move
>> to new line" so the output is all on one line:
>> =============================================== \n               Beginning of
>> Program \n=============================================== \n
>> While not the end of the world, it is a bit annoying. Am I screwing up the
>> calling sequence and just got lucky with g95?  Or a bug (PETSc or Intel)?
>> Thanks,
>> Paul
>> P.S. The reason why I care is because on any compiler I've used (other than
>> Intel), write(*,*) prints out at different times and not in sequence with
>> PETSc so all my output comes out after PETSc is done outputting. Using
>> PetscPrintf, I can have everything print out in order.
