PetscPrintf/ifort 9.1
Matthew Knepley
knepley at gmail.com
Tue Aug 28 19:05:20 CDT 2007
On 8/28/07, Paul T. Bauman <pbauman at ices.utexas.edu> wrote:
> Hello,
> Kind of a non-numerical question - sorry. I'm using PetscPrintf from
> Fortran using the following calling sequence (for example):
> call PetscPrintf(PETSC_COMM_WORLD,
> "=============================================== \n", ierr)
> call PetscPrintf(PETSC_COMM_WORLD, " Beginning of
> Program \n", ierr)
> On my mac laptop (PowerPC) with PETSc 2.3.2-p7 compiled with gcc 4.0.1
> and g95, this prints as expected:
> Beginning of Program
> On a linux workstation (AMD Opteron) with PETSc 2.3.2-p7 compiled with
> icc, icxx, ifort 9.1, the "\n" is treated as a character and not treated
> as "move to new line" so the output is all on one line:
> Beginning of Program \n=============================================== \n
This is much lower level than PETSc. It is in the C standard. There
must be something
else going on here. We do this EVERYWHERE in the code. For instance,
why would the
-ksp_monitor output work. This uses \n in exactly the same way.
Matt
> While not the end of the world, it is a bit annoying. Am I screwing up
> the calling sequence and just got lucky with g95? Or a bug (PETSc or
> Intel)?
> Thanks,
> Paul
> P.S. The reason why I care is because on any compiler I've used (other
> than Intel), write(*,*) prints out at different times and not in
> sequence with PETSc so all my output comes out after PETSc is done
> outputting. Using PetscPrintf, I can have everything print out in order.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
