using MatCreateSeqBDiag
Matthew Knepley
knepley at gmail.com
Tue Aug 28 12:05:18 CDT 2007
On 8/28/07, Alejandro Garzon <gtg100n at mail.gatech.edu> wrote:
> Hi, I'm trying to use MatCreateSeqBDiag. I wrote a small test program
> to see how this function works. The program creates a matrix A,
> prints it in matlab ascii format and in binary format, then creates a
> vector x, calculates A*x and puts the result in vector b.
> I have found the following inconsistencies:
> 1) While I intended the matrix to have real elements, it is printed in
> matlab ascii format as if all the elements were imaginary. The
> elements are correct except for an extra "i" to the right of all of
> them.
This was a cut&paste error. Fixed.
> 2) When printed in binary format, the matrix appears with all its
> elements set to zero.
Fixed this now too.
These fixes will appear in the next patch release. Hopefully before the end of
the week.
Thanks for reporting these,
Matt
> 3) The internal representation of the matrix seems to be Ok as a
> matrix-vector multiplication A*x gives the right result (without the
> i's).
> The source code and the output of the program are below. Can you take
> a look at it and tell me if the I haven't built the matrix in the
> right way or if it could be a bug in the MatView function when
> handling this matrix format ? Thanks.
> // ************** Source code program *********************
> // This code is for checking the usage of MatCreateSeqBDiag
> #include<stdio.h>
> #include<stdlib.h>
> #include"petscksp.h"
> int main(int argc,char **args)
> Mat A;
> Vec x,b;
> PetscInt diag[9],ixm[10];
> PetscScalar **diagv,*diagv1,vval[10];
> int i;
> PetscViewer v;
> PetscErrorCode ierr;
> PetscInitialize(&argc,&args,(char *)0,(char *)0);
> // A 10x10 matrix with 2x2 blocks will be build.
> // Only blocks in the main diagonal will be filled.
> diag[0]=0;
> diagv=malloc(1*sizeof(PetscScalar*));
> diagv1=malloc(20*sizeof(PetscScalar));
> // The main block diagonal will contain the numbers from
> // 1 to 20
> for(i=0;i<20;i++){
> diagv1[i]=(i+1.0);
> diagv[0]=diagv1;
> ierr=MatCreateSeqBDiag(PETSC_COMM_WORLD,10,10,1,2,diag,diagv,&A);
> CHKERRQ(ierr);
> ierr=MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr=MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> // Printing matrix A to the stardard output in matlab ascii format.
> ierr=PetscViewerSetFormat(PETSC_VIEWER_STDOUT_WORLD,
> PETSC_VIEWER_ASCII_MATLAB);CHKERRQ(ierr);
> ierr=MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> // Printing matrix A to binary file "binary_file"
> ierr=PetscViewerBinaryOpen(PETSC_COMM_WORLD,"binary_file",
> FILE_MODE_WRITE,&v);CHKERRQ(ierr);
> ierr=MatView(A,v);CHKERRQ(ierr);
> // Building vector with all elements equal to 1
> ierr=VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);
> ierr=VecSetSizes(x,PETSC_DECIDE,10);CHKERRQ(ierr);
> ierr=VecSetFromOptions(x);CHKERRQ(ierr);
> for(i=0;i<10;i++){
> ixm[i]=i;
> vval[i]=1;
> ierr=VecSetValues(x,10,ixm,vval,INSERT_VALUES);CHKERRQ(ierr);
> ierr=VecAssemblyBegin(x);CHKERRQ(ierr);
> ierr=VecAssemblyEnd(x);CHKERRQ(ierr);
> // Printing vector x to standard output in matlab ascii format
> ierr=VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> ierr=VecDuplicate(x,&b);CHKERRQ(ierr);
> // b = A*x
> ierr=MatMult(A,x,b);CHKERRQ(ierr);
> // Printing vector b to standard output in matlab ascii format
> ierr=VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> PetscFinalize();
> return 0;
> // ****************** Program output *********************
> % Size = 10 10
> % Nonzeros = 20
> zzz = zeros(20,3);
> zzz = [
> 1 1 1.0000000000000000e+00i
> 1 2 3.0000000000000000e+00i
> 2 1 2.0000000000000000e+00i
> 2 2 4.0000000000000000e+00i
> 3 3 5.0000000000000000e+00i
> 3 4 7.0000000000000000e+00i
> 4 3 6.0000000000000000e+00i
> 4 4 8.0000000000000000e+00i
> 5 5 9.0000000000000000e+00i
> 5 6 1.1000000000000000e+01i
> 6 5 1.0000000000000000e+01i
> 6 6 1.2000000000000000e+01i
> 7 7 1.3000000000000000e+01i
> 7 8 1.5000000000000000e+01i
> 8 7 1.4000000000000000e+01i
> 8 8 1.6000000000000000e+01i
> 9 9 1.7000000000000000e+01i
> 9 10 1.9000000000000000e+01i
> 10 9 1.8000000000000000e+01i
> 10 10 2.0000000000000000e+01i
> Mat_0 = spconvert(zzz);
> Vec_1 = [
> Vec_2 = [
> 2.2000000000000000e+01
> 2.8000000000000000e+01
> 3.0000000000000000e+01
> 3.6000000000000000e+01
> 3.8000000000000000e+01
> Alejandro
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
