Is this the correct way to use MatGetRow? Something wrong here
Ben Tay zonexo at gmail.com
Mon Aug 27 06:19:06 CDT 2007
I'm trying to view a particular row of a matrix. This 's what I do in my
loops:
real(8):: vector(64)
II=36
impl_mat_i=4.
call MatSetValue(A_mat_uv,II,II,impl_mat_i,ADD_VALUES,ierr)
call MatAssemblyBegin(A_mat_uv,MAT_FINAL_ASSEMBLY,ierr)
call MatAssemblyEnd(A_mat_uv,MAT_FINAL_ASSEMBLY,ierr)
call MatGetRow(A_mat_uv,II,PETSC_NULL,PETSC_NULL,vector,ierr)
call MatRestoreRow(A_mat_uv,II,PETSC_NULL,PETSC_NULL,vector,ierr)
When I look at "vector" using visual fortran debugger, I saw many
different values in it, but I only added 1 value in 1 location. However,
just before I use MatSetValue, I also called MatGetRow. It was initially
all zero.
But, if I use call
MatSetValue(A_mat_uv,II,*1*,impl_mat_i,ADD_VALUES,ierr) instead of II, I
see only 4 in vector(1).
What happening? Where did all the other values come from? Also, is this
the best way to view a particular row of a matrix? I tried to use
call MatGetValues(A_mat_uv,1,36,64,1,vector,ierr) to get 1 row of values
from the 36th row.There are 64 columns in total. Seems like it's the
wrong way. Can you please show me the correct way?
Thank you.
